View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124
  1. engine block color 63 Avanti
  2. Engine id's
  3. ENGINE IGNITION AND OIL PRESSURE
  4. Fog Light Bulbs
  5. radiator
  6. frame speader
  7. 53 Truck Radiator
  8. 53 Truck
  9. 61 hawk dash pad
  10. 4 speed shifter question-63 Lark
  11. What Is This Part ?
  12. Need Help!
  13. frame correction 1961 hawk
  14. Here' something wierd for ya...
  15. 63 cruiser 259
  16. Worn threads in control arms?
  17. Rod Bearing Replacement
  18. Super Charger O-rings
  19. Inner bushings
  20. OIL FILTER
  21. pinion gear
  22. 289 Ignition Timing Question
  23. hood & trunk lid will not shut and protrude
  24. Single or dual exhaust?
  25. fender headlight repair
  26. Wet sanding finish
  27. 55 prez coupe did it come whith a dash cover
  28. '56 Parkview Wagon Hill Holder questions...
  29. 59 lark radiator leak
  30. WANTED '47-'48 Studebaker Champion Business Coupe
  31. 60 Lark Heater Control Valve
  32. '55 President Neutral Safety/Backup Light Switch
  33. King pins
  34. Dual master cylinder, work when line ruptures?
  35. New to Studebaker
  36. 1962 Hawk Clips
  37. Rear leaf springs
  38. strange screws on factory mirrors ?????
  39. sluggish switches-- o'drive won't slide...fix ??
  40. 58 Scotsman master cylinder removal woes
  41. Pushrods?
  42. cam gear knock
  43. Just bought a '63 Lark
  44. 53 Commander Coupe Rear Axle
  45. Flight-o-matic to 4 speed conversion
  46. We gotta talk about this again...
  47. Underhood Detailing
  48. 13/16 die for steering fine thread
  49. New wiring harness
  50. Mouse bucket
  51. raido
  52. 4 on 4 bolt pattern on '47 Champion
  53. Torque #'s
  54. Replacing Cork floats on Fuel Senders
  55. 5 hole budd wheels 19.5 or 22.5
  56. Painting Discussion
  57. restoration details on a 60 Lark engine needed
  58. body shimming
  59. master cly
  60. electronic ignition
  61. Check those brakes
  62. How to seal leaking fuel level sender?
  63. Amp Light
  64. Lowering a Stude. How To?
  65. winged doors
  66. Brake Line Bracket
  67. Hawk Power Steering
  68. column shift modification?
  69. head swap
  70. Power Steering
  71. Loud or Quite Tone Mufflers?
  72. brake light and signal problem
  73. Filler on epoxy primer test
  74. emblem
  75. Shoulder belts install?
  76. Hill Holder question
  77. 1954 Conestoga Bumper.
  78. special interior
  79. C cab dual exhaust
  80. Who's the Best?
  81. T10 transmission I.D help needed.
  82. Installing a Overdrive Solenoid
  83. Power seats OT, but Stude content...
  84. Lark e-brake clevis rod found
  85. adjustment CO%
  86. Long or short Tailshaft trans in a 57 Hawk six?
  87. '56 Parkview overheated on trial run...
  88. Need an O/D Solenoid!
  89. door trim removal on 1961 hawk
  90. Vinyl tops
  91. What rearend do i have?
  92. 56 wagon rad. interchange
  93. Spark plug for '56 President 289 V8?
  94. How to best install fender welt
  95. Positive or Neg Ground?
  96. Replacement scuff plates source needed
  97. radio antenna no up or down
  98. Setting the pinion angle
  99. spark plugs for stude
  100. 58 Golden Hawk Valve Covers Decal ??
  101. 58 Golden Hawk Valve Covers Decal ??
  102. Back Glass
  103. 48 CHAQMPION STEERING WHEEL
  104. trans swap 50 to 55 6 cyl to v8
  105. hardtop specific trim/rubber
  106. wheel experts
  107. Studebaker/Lark Brake Interchange
  108. A bad e-mail to our mrmbers
  109. Engine: Intake Manifold Installation
  110. leaf spring bushings
  111. sn92 paxton has a serpentine belt dr on it can
  112. What size fender welt?
  113. which way to install hood to cowl weatherstrip?
  114. Champion 6 ID
  115. horn ring 61 hawk
  116. Custom Steel Wheel Back Spacing
  117. T-9 & T-97 truck transmissions
  118. Another Hill Holder question
  119. Carb Issue
  120. WILL A WCFB CARB WORK WITH SN92
  121. Yet more Hill Holder function questions...
  122. Different Oil Pumps
  123. '55 President transmission
  124. 50 champ nose on 48 commander
  125. '47 Champ backfires will not run
  126. Rear axle tech triva
  127. where can i get a fuel pump set up for sn92
  128. Stupid engine painting question
  129. '55 President Gas & Water Temp. Gauges
  130. Wanted Avanti rear seat
  131. Suspension question
  132. Lousy rotten exhaust manifold studs!
  133. Brake light woes
  134. Metering rods and Jets
  135. 1951 2R5 truck
  136. Heater control valve
  137. Fender welt installation
  138. Hawk gas tank question
  139. Carter Climatizer choke adjustment
  140. float mods on a marine edlebrock carb
  141. Aerostar suspension adapter
  142. question from an old member
  143. Hawk serial number question
  144. New forum feature added (and a request)
  145. Help!
  146. Commander Head Replacement
  147. 47 studebaker m-5 truck
  148. Rust/help/question
  149. Torque converter
  150. Hi Altitude jets- Golden Hawk
  151. horn emblem
  152. 6 CYL 3sp Trans interchanges with ?
  153. 63GT New motor mounts-GROUNDS ?
  154. I feel reeeeally stupid asking this buuuuut...
  155. What the??
  156. LICENSE PLATE FRAME - MOUNTING
  157. Throttle bellcrank - painted or not?
  158. Remanufatured Studebaker motors
  159. Speedometer core broken 62 Hawk
  160. .
  161. 61 hawk automatic trans
  162. '47 rear window glass installation...how ??
  163. '62 Hawk Tranny fluid type F?
  164. 1950 STUDEBAKER LANDCRUISER WINDSHIELD VISOR
  165. Engine rear main seal
  166. Bleeding Brakes
  167. Brake Drum Interchange Anyone?
  168. Outside mirror issue
  169. Just Finished Installing Adjustable Traction Bars!
  170. 232 V8
  171. loose rear view mirro
  172. Hubcaps
  173. Pulley mounting
  174. brakes
  175. Linkage question
  176. Air Conditioning
  177. Good source for vaccum advance on '56 V8
  178. wiper motors
  179. So I tried the Tremclad with a roller technique...
  180. pinion seal
  181. Cost of Rebuildable Engine
  182. Mechanical brakelight switch for '64 Lark
  183. fluids
  184. GT door latch/striker
  185. Anyone with experience installing CE's Lark pans?
  186. Rear Brake Drum
  187. backfiring out both ends
  188. 63 Lark Belt #
  189. Tranny & OD gear oil ?
  190. 62 lark front fenders
  191. GT Hawk Distributor Finish
  192. 37 engine tech help
  193. 1953 hardtop speedo
  194. Part # For C-Cab
  195. Heater control valve
  196. proper catalog part name???????
  197. smoky '65 cruiser
  198. broken Headlamp bucket
  199. Shifter realization...parts availability???
  200. Missing Hawk Body Mounting Parts
  201. Posting a Picture in Members Studebakers
  202. Adjusting torque values for Loctite
  203. Fiberglass lark stuff?
  204. 57 Golden Hawk Air Cleaner
  205. Underhood detail
  206. 57 golden hawk with 4 speed
  207. Knocking noise - ohv6
  208. Which 289 distributor?
  209. Oil filter for the old stude
  210. Direction of water flow
  211. 59 Scotsman truck update
  212. 1961 hawk door outside door handles
  213. Kick down
  214. Auto choke
  215. Frozen engine
  216. Looking for pulley
  217. Water pump installation
  218. Dome light mal-function
  219. engine temps
  220. 12V Horns
  221. Studebaker Paint
  222. Power Brakes for 63 Lark
  223. Was there Ever a Pressure Gauge in a R2 Hawk
  224. oil filters
  225. Resto tip - using 2-sided tape
  226. Paint stripping info
  227. Crankshaft pulley flange
  228. GT Hawk Emblems
  229. FLAT TAPPET OIL (original post deleted)
  230. Original City Destination
  231. Supercharger Idler Pulley Bearing
  232. brake lines and switch
  233. Will 64 Lark seat covers fit 63 frames?
  234. Steering Studebaker Power Steering Pump Rebuild - how to
  235. Electronic ignition for a R2 289 Avanti ( 63 )
  236. New carpet
  237. Hawk Wheel Bearing adjustment?
  238. Calling Mr. Biggs
  239. Power Brake 63 Lark
  240. Heater Control Valve Wire
  241. 185 piston orientation
  242. changed to pos ground?
  243. Replacing front signal socket
  244. '51 Engine color, etc
  245. Wet vs. dry air cleaners
  246. rivets
  247. wiring diag for alternator
  248. Amp meter , max load
  249. 100% Neetsfoot Oil
  250. 185 Hot-rodding
