View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Borg Warner auto tranny in '55 President
  2. Oil line locations on Champion engine
  3. 289 Heads
  4. Caddy swap
  5. Silly brake question-more questions!
  6. Dana Rear End Question?
  7. Bucking on Coast Down ?
  8. Crank End Play Spacers
  9. Cam Lube
  10. 1953 Studebaker - what does this mean?
  11. jack stand placement for storage
  12. timing
  13. Vacumn tube ??
  14. okayyy.The Champ brakes are different, how much?
  15. New Brakes Work Wonders
  16. new 1154 bulbs too long for socket ????
  17. Door Panels
  18. Quarter Window replacement
  19. For the Stude tool collectors
  20. 1950 studebaker 4 lug wheels
  21. 1955 Sedan Pres brake system problems?
  22. GM motor placement in Avanti stainless frame
  23. 62 hawk
  24. GT Hawk steering box problem
  25. Rear leaf springs for a Hawk
  26. Trailer Towing Safely
  27. Need radio help
  28. winterizing my stude....
  29. Woodruff key position?
  30. Black is relative?
  31. caring for interior
  32. lark rack and pinion steering
  33. Return on wheel cylinders.
  34. POR-15 floorboards
  35. 62 Hawk wheel question
  36. hawk track width
  37. 31 STUDEBAKER 6, MODEL 54
  38. Parts swapping for auto 1st gear start
  39. Four speeds for Larks
  40. dropped keeper
  41. C-Cab Headliner Pattern
  42. Zinc in engine oil?
  43. Lark traction bars
  44. Subframe swaps
  45. turn signal help help help
  46. No lights
  47. cam gear update
  48. 55 STUDE
  49. WHOW TO 6 VOLT TO 12VOLT 55 STUDE
  50. avanti ash tray
  51. Hawk Dash in a 53 Commander
  52. Heater Filter?
  53. Wet Feet!!!!
  54. Best location to hook up an accessory heater?
  55. 1950 3 speed manual
  56. glass
  57. torque converter for DG 250
  58. amp meter or volt meter
  59. Trim paint
  60. Got the Caddy running
  61. Instrument Cluster Restoration
  62. Pertronix for the 170 6 Cyl?
  63. OD cable
  64. Directional Signal Switch
  65. Funny Looking Bulletnose
  66. A mini Milestone
  67. Where to get bushings?
  68. 02 Sensor?
  69. Hawk taillight Housing question
  70. Avanti engine info
  71. paint colors
  72. 1961 hawk project
  73. When did Studebaker switch to the 12 volt system?
  74. 63 vs 64 rocker panels
  75. Choose Studebaker wheels
  76. Delrin Bushings
  77. Freeze Plugs
  78. 1961 HAWK SPECIAL DASH PLAQUE
  79. No spark
  80. Low octane cure
  81. Speedometer rehabililtation
  82. Speedometer Cable
  83. C cab gas guage
  84. '57 Prez diff ratio
  85. Motor Location problem-63 Hawk
  86. M5 weatherseal question
  87. 51 Studebaker Champion What Air Cleaner?
  88. Transmittion 39-40 Champion
  89. cork floats on gas sending unit----fix ????
  90. Speedster center horn
  91. Identification
  92. Kemco Octane Improver?
  93. 51 Stude Champion Air Cleaner Ebay
  94. Door Removal
  95. For Jeff and other classic rodders...
  96. avanti plug fouling
  97. where can i get a supercharger my 55 stude 259 cu
  98. Underhood Light Identification ?
  99. 56 Champion Alternator conversion?
  100. Need balancer ring
  101. Front clip removal
  102. Water pump installation tip
  103. Rear Axle Question
  104. 1961 hawk
  105. Air Cleaner 51 Champion
  106. 1950 Studebaker
  107. 50 Champion Trans
  108. Body mounts to eliminate Avanti hog troughs
  109. How to find original owners name ?
  110. ned info for floor shift in truck
  111. Seat Belts
  112. need some information
  113. '55 President fuel pump
  114. '55 President engine mounts
  115. 1951 2R5-12 truck front leaf springs
  116. Engine ID
  117. Hawk heater switch
  118. the Phoenix rises....
  119. Where to post
  120. Caddy test fit
  121. Bed Size
  122. head bolt sequence
  123. 259 rebuild
  124. Overdrive Solenoid Oil Seal
  125. Hawk engine removal?
  126. R2 Hawk air cleaner
  127. 170 ohv and '52 overdrive tranny -- odd couple?
  128. 60 Hawk Brakes or NOT
  129. Has anybody rebuilt a steering cylinder??
  130. '51 Auto Tranny leak
  131. Window Regulator
  132. Hawk Plug Wires
  133. Now this is cool,
  134. '55 President Torque converter housing
  135. 50 champion brake problem revisited
  136. Picture test.
  137. Removing body from chassis
  138. what is the metal gauge for fenders and ???
  139. Paint Colors
  140. Mr. Shaw,please,
  141. frame question
  142. Rear end swap for a 64 Lark Type?
  143. Commander Front springs
  144. 50 Champion back up light?
  145. 56 Wagon Rearend
  146. '56 259 VS '62 259 compatible waterpumps?
  147. 100 amp Caddie alternator in a Champ... wiring???
  148. Neutral Safety Switch
  149. casting number
  150. heater inquiry
  151. What transmission was used???
  152. PARKING PAWL
  153. how wide of tire can run on back 55 prez coupe sto
  154. Question for the rodders
  155. Anti-freeze in intake manifold
  156. '50 Champion Engine/Tranny Pull
  157. frame rail
  158. FOM rebuild -I did it!
  159. 1950 Studebaker Trans
  160. The front end
  161. Rear-end Gear ratios
  162. Stainless brake hose
  163. studebaker/volvo engine
  164. Transmission Shop
  165. backup lights
  166. Carburettor Size
  167. Wiring Question
  168. Drive shaft 101
  169. Diesel engines in the Lark?
  170. GT Hawk steering column seal
  171. rain gutter
  172. Quarter and fin removal
  173. Saginaw-Ross steering gear swap
  174. Cobra Brake brackets first article set from CNC
  175. Differences in the 6 cyl 59 and 60 Larks, OD?
  176. O.D. from a R/////bler
  177. 1961 hawk front grills
  178. Avanti power steering system rebuild Q & A
  179. Tailpipe emissions???
  180. WTD: Stude woodgrain photos
  181. 55 mph rear axle snap!
  182. who make the best seat covers 55 prez coupe
  183. 1951 studebaker 2r5
  184. '55 clock to a '56 dash?
  185. What is this wheel cover for 196?
  186. 4 speed bellhousing???
  187. Avanti fuel door modification?
  188. Auto floor shift
  189. Steering Column tube removal
  190. 64 Daytona blower motor removal
  191. Converting from power brakes to manual
  192. Thermostat
  193. Only wants to start when pulled!
  194. Stop lamp switch replacement
  195. best method to clean an old fuel line ??
  196. headlights not working..........fix ??????
  197. gas tank sending unit wire fix ????
  198. new keys and lock retainers in the doors a fix
  199. 52 STUD HEATER
  200. Removing "c body" cowl mldgs
  201. Hydrovac "neetsfoot oil,,,,piston oil?
  202. dash and floor starter switch in one car
  203. Nice Day For A Drive
  204. hot 2 both sides of coil and then cold...fix ???
  205. Air Conditioning '60 Lark VI
  206. frame coming off 1961 hawk
  207. Ride Height on 53 Commander Starlight Coupe
  208. 120-140 compression what if lower ????
  209. Rear Drum Removal
  210. external-internal tooth lock washer when do you
  211. Swapping the 170 for a 259 or...
  212. overdrive switch moved to manual gear shifter
  213. Steering Column
  214. alternator vs generator
  215. copy blank invoice
  216. RMI-25 as replacement for hand picking out rust
  217. Replacing the genny in a '56 wagon with a GM Alt.
  218. Steering wheel nut
  219. R2 Lark Scarcity???
  220. A pillar support
  221. Brake Pedal Replacement
  222. Brake drum removal
  223. 1963 Avanti
  224. window regulator
  225. Convert Avanti power to manual windows
  226. brake shoe disentegration possible ??
  227. FOM Transmission help needed!!
  228. overdrive in '56 Parkview wagon
  229. 289 valve cover stud grommets
  230. Air cleaner tube 289 V8
  231. Engine serial number
  232. Interesting discoveries today....
  233. What do I look for? Dan C.
  234. 52,51 Champion heater/defroster
  235. Tail lights '53 vs '56?
  236. Crankshaft and Hub distance
  237. 1957 Scotsman question
  238. 232 rebuild
  239. Wiring harness
  240. GT Hawk alternator and disk brake stickers
  241. I need car parts
  242. Ignition Switch Lock Up
  243. The Lark's Brakes
  244. Front-end vibration
  245. Under Hood Brake Resevoir GT Hawk
  246. Engine cut out
  247. Need a Starter
  248. Crankcase Venting for a 289
  249. '47 left rear curved glass interchange
  250. Transmission Number
