View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 [117] 118 119 120
  1. Fuel System: Carby swap
  2. Electrical: Cruise Control on 6V car
  3. Engine: Can anyone I.D. this?
  4. Speedo/Tach/Gauges Removing Dash
  5. Cool/Heat: Radiator replacement for a 56 transtar
  6. Interior: Alternative to staples for attaching cat whiskers??
  7. Brakes: how does the power brake sytem work?
  8. Cool/Heat: 170 OHV Water Pump
  9. Ignition: Ignition issue on 6-volt 1950 2R5
  10. Speedo/Tach/Gauges Water Temp Gauge not working
  11. Cool/Heat: Engine Running too cool
  12. Brakes: Torque spec
  13. Engine: water jackets and head bolts
  14. Rear Axle: Posi l6 rear end?
  15. Speedo/Tach/Gauges Inaccurate Speedometer
  16. Fuel System: dies at idle....Problem Solved!
  17. Brakes: Rear Brake Drums
  18. Interior: Interior light switch 62 hawk
  19. Cool/Heat: Thermostat Housing 1550844
  20. Body: '47-'52 coupe rust repair under rear fenders
  21. Rear Axle: Axle broke
  22. Ignition: electronic distrubutor ballast resistor
  23. Engine: Eliminating the oil filter 51 Landcruiser
  24. Fuel System: wcfb jet size
  25. Electrical: Solved horn not working issue in 1952 Champion by doing this
  26. Body: Part ID? - 1338946
  27. Engine: Vacuum reading variations
  28. Shocks Lower shock mounts moving over
  29. Body: Need a Tailgate, '49 Stude 3/4 Ton Truck
  30. Engine: unspeakable swap question
  31. Electrical: 1958 Silver Hawk need help
  32. Electrical: Need nobworking voltage regulator
  33. Steering No right turn return.
  34. Electrical: Trunk light switch?
  35. Engine: Partial Flow Filter Orifice Fitting on 54 Commanders
  36. Body: Hood Prop Rod
  37. Engine: Correct oil filter for 57 Golden Hawk
  38. Ignition: Ignition switch
  39. Frame/Springs M5 rear springs
  40. Rear Axle: Shop manual
  41. Cool/Heat: My 52 Studebaker Champion cooling question?
  42. Interior: Hosing this thing out!
  43. Brakes: turner brake problems
  44. Wheels Champ wheel substitution options
  45. Body: Lower C-body door hinge hardware
  46. Exhaust Exhaust &...
  47. Engine: Lark Engine
  48. Cool/Heat: Gooseneck question?
  49. Transmission: Pre War Champion Tansmission Problem
  50. Cool/Heat: Evans waterless engine coolent
  51. Engine: Intake manifold leak
  52. Cool/Heat: Jeep radiator in X frame cars
  53. Cool/Heat: clutch fan vs. solid mounted fan
  54. Steering Bellcrank
  55. Steering Power Steering In R Series Truck???
  56. Engine: Need Timing info for a 259
  57. Other: 64 Lark Power Antenna
  58. Fuel System: 64 Avanti Runs, after 5 minutes stalls
  59. Body: '56 Hawk Hood
  60. Electrical: 1962 Hawk Wiper Switch
  61. Rear Axle: In need of Dana 27 axle shift.
  62. Body: How to removed delicate molding?
  63. Body: How to remove delicate molding?
  64. Engine: Engine number
  65. Ignition: Vacuum advance on 289
  66. Rear Axle: Axle removal
  67. Electrical: Adding turn signals to 1940 Champion
  68. Front Axle: Front Suspension Thrust Bearing
  69. Electrical: Tachometer conversion
  70. Other: Rubber parts
  71. Electrical: Wiring Harness With or Without Turn Signals
  72. Transmission: Final gear
  73. Frame/Springs best place to buy avanti rear springs
  74. Engine: New 6V Starter Solenoid
  75. Steering Power Sterring
  76. Fuel System: Studes with AC style glass fuel filter.
  77. Fuel System: tpe of metal
  78. Cool/Heat: 1955 Commander Project: Heater Hose
  79. Fuel System: Fuel tank to fit 1937 Coupe
  80. Body: Barrel Nut?
  81. Cool/Heat: 64 Wagonaire fan shroud
  82. Body: blasting media?
  83. Steering '60 Hawk needs steering box rebuilt
  84. Brakes: Location of E brake spring?
  85. Fuel System: fuel line size
  86. Ignition: Can Anyone Shed Light On This Distributor??
  87. Fuel System: Carburetor identification- 1944 Weasel
  88. Engine: champion head swap
  89. Fuel System: fuel tank 54 champion
  90. Brakes: Brake shoes, bonded vs. rivited.....from the GTO guys, made me laugh big time:-)
  91. Fuel System: Demon Carb On 56J
  92. Wheels 16" '37 Dictator wheel - also fits?
  93. Steering front pins 62 hawk
  94. Electrical: 64 Champ wiring 1st question
  95. Brakes: Brake Pedal V-e-r-r-r-r-r-y Slow To Return
  96. Body: Hawk core support
  97. Engine: Need a blower for a Lark....
  98. Brakes: Forgot it's position
  99. Cool/Heat: 64 Wagonaire fan blade
  100. Engine: Need help mounting stock 64 Air Compressor to a R1 Avanti
  101. Other: 1957 Golden Hawk oil plug question.
  102. Ignition: 1916 Studebaker Roadster - Wagner 6 volt Generator
  103. Fuel System: 6-volt electric fuel pump question
  104. Transmission: shifter kit?
  105. Rear Axle: Rear axle type
  106. Fuel System: Mileage, Chevybaker
  107. Brakes: Need 56 Power Hawk e-brake info
  108. Cool/Heat: Add on air conditioning
  109. Interior: 56 Hawk seat belt installation
  110. Electrical: 1929 Dictator. HELP! What is the timer for behind the dash
  111. Wheels 1954 wheels
  112. Body: floor panels replacement
  113. Other: Convertible Top Motor
  114. Paint: 1964 Astra White
  115. Cool/Heat: Water pump bad?
  116. Shocks installing shocks
  117. Body: What grade rubber for making gaskets.
  118. Brakes: Vacuum Booster
  119. Ignition: How much end play on a Delco Distributor?
  120. Electrical: Battery cables
  121. Paint: 1966 Daytona Fan and Trans dipstick colors
  122. Body: hawk side grills
  123. Ignition: Where should the rotor point?
  124. Frame/Springs custom chassis
  125. Brakes: When replacing rear brake shoes
  126. Transmission: Need lead on 26 tooth pinion gear #531202
  127. Fuel System: OHM range on fuel sending unit - 1937 Dictator model
  128. Rear Axle: Removing Dana 44 pinion seal
  129. Brakes: Master Cylinder Avanti
  130. Body: Car cover info wanted
  131. Electrical: Parking lights
  132. Engine: ZDDPlus vs LUCUS products
  133. Fuel System: 1948 M5 Gas Tank
  134. Fuel System: 49 Champion fuel issue
  135. Ignition: Distributor Hold Down Clamp
  136. Ignition: Photo Request (54 distributor vacuum line)
  137. Interior: Hawk Padded Dash
  138. Brakes: Dual master on Studebaker Avanti
  139. Electrical: Commander radio removal
  140. Front Axle: President 8 tie bars missing ?
  141. Frame/Springs Rear Motormount Cross Member
  142. Ignition: Ignition Coil & Ballast Resistor Matching
  143. Engine: bad engine rebuild experience
  144. Clutch/Torque Converter: Installing a Ring Gear
  145. Body: 56 hawk fins
  146. Electrical: 1962 Hawk Wiper Switch
  147. Wheels What type and size wheel to use with radial tires
  148. Body: Hi-Tone Horn
  149. Rear Axle: 59 truck rear end
  150. Speedo/Tach/Gauges 2.72 rear gear
  151. Brakes: Hawk Parking Brake Spacer
  152. Interior: Hole saw needed to cut hole for throttle in floor
  153. Fuel System: Which WW carburetor to use.
  154. Speedo/Tach/Gauges ?Is there a So Cal shop to repair my orig Bourdon temp gauge? 1950 2R5 pickup w/269 cid
  155. Electrical: 1962 Studebaker Hawk Wiper
  156. Shocks I need new shock absorbers.
  157. Cool/Heat: A/C for a 1948 Commander
  158. Speedo/Tach/Gauges Speedo needle jumps around
  159. Body: 1959 Lark Wagon rear side glass channel
  160. Electrical: What is the best way to route my horn wire?
  161. Interior: 1963 Avanti rear package shelf is sagging from water and age
  162. Engine: Pan gasket installation on 289 V8
  163. Speedo/Tach/Gauges Cruise Control installed in my '62 GT Hawk
  164. Ignition: What years???
  165. Wheels Wheel/Tire question for those who know Hawks
  166. Fuel System: MPG With Demon Carb
  167. Electrical: Where to add ground straps
  168. Body: 1929 commander front windshield
  169. Body: 61 fenders
  170. Steering Avanti; Ross Steering Box
  171. Electrical: 54 Commander (6V) turn signals
  172. Engine: vacuum port quesrion
  173. Fuel System: 6-volt electric fuel pump question--results
  174. Engine: gasket construction of Studebaker International V8 head, manifold gaskets
  175. Electrical: wiring diagram for 1965
  176. Engine: Dip Stick Tube
  177. Interior: Vinyl Dye
  178. Body: under rear bumper
  179. Fuel System: Fuel sending unit - 1937 Dictator
  180. Body: Chrome Crazing Question
  181. Body: Keyed Alike
  182. Fuel System: Installing Electric Fuel Pump
  183. Clutch/Torque Converter: 1956 G-Hawk question
  184. Paint: Waxes to use/avoid for vintage paint job?
  185. Engine: GT Hawk backfires out exhaust
  186. Steering Ross gear in Avanti
  187. Frame/Springs and this bolts together how? 63-66 V8 stabilizer bar frame brackets
  188. Engine: What part number is this?
  189. Brakes: 57 Golden Hawk, Problems with brake bleeding (with Hydrovac Power Brake Booster + Hill Holder)
  190. Brakes: 54 Commander pulls to the right after shoe replacement
  191. Body: S 35 Ventshades
  192. Clutch/Torque Converter: Engine killing when put in gear. Issue solved
  193. Transmission: Tranny fluid??
  194. Engine: Removing square head steel drain plugs easily
  195. Steering Anyone tried a power rack and pinion steering in a Champ Pick Up?
  196. Cool/Heat: Radiator - 48 Commander
  197. Frame/Springs replacement of hidden nut
  198. Engine: Performance (carb) issues fixed...1953 2R6
  199. Steering Power Steering for 6 cyl. Lark
  200. Engine: Never change oil?
  201. Transmission: Entire drivetrain from bellhousing back
  202. Interior: Best Chrome Polishing Method & How to Keep Whitewalls White!
  203. Brakes: ‘64 Hawk M/C Reservoir
  204. Steering 54 Commander steering is hard to the right
  205. Brakes: M5 - how to adjust brakes?
  206. Body: Window Glass Rollers/GT Hawk
  207. Engine: Oil tube
  208. Electrical: '63 Avanti horn not operating (well, sometimes)
  209. Frame/Springs Hawk Frame swap
  210. Electrical: tach repair
  211. Electrical: 1962 Hawk headlight control switch
  212. Clutch/Torque Converter: Clutch adjustment
  213. Ignition: high tech distributor
  214. Electrical: trunk mounted antenna
  215. Body: Hood adjust
  216. Ignition: Ignition switch
  217. Engine: Engine break in
  218. Engine: Flywheel Pilot Bushing
  219. Interior: What is the orientation of the turn signal switch lever knob?
  220. Rear Axle: Did Studebaker ever use a posi in 1960 on a Hawk?
  221. Body: door hinges
  222. Transmission: T86 E 1A rebuild question
  223. Electrical: 6 volt or 12 volt? what to do? '46 M5 pickup
  224. Cool/Heat: Sanden compressor install.
  225. Speedo/Tach/Gauges '62 GT Hawk Tachometer
  226. Body: Trunk light
  227. Transmission: 65 / 66 V8 Stick Bellhousing
  228. Body: 1962 Hawk Hood Fit
  229. Body: floor pan replacement
  230. Steering Power Steering Control Valve
  231. Paint: pickup tailgate lettering
  232. Electrical: INTERSTATE Group 24 Battery
  233. Electrical: 2R5 horn button
  234. Body: 74 Avanti door panel color change
  235. Engine: WTB 289 Crankshaft
  236. Body: Shop manual
  237. Interior: original color/look
  238. Cool/Heat: Late V8 Six Blade Fan
  239. Paint: under body color
  240. Electrical: Rewiring 2R5 - Looking for someone to help with it
  241. Brakes: Hydro Power Brakes
  242. Transmission: 53 Commander DG 200
  243. Body: Re-Doing Door Panels
  244. Transmission: What is the oil capacity of the T10?
  245. Fuel System: KBS gas tank sealer?
  246. Front Axle: Need number off outer bearing race URGENTLY
  247. Fuel System: Oil Pressure Switch for Electric Fuel Pump
  248. Engine: Replacement starter motor for my 1937 Dictator
  249. Engine: 1955 Commander: Engine Won't Turn Over (again)
  250. Body: Hood insulation
