View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 [116] 117 118 119 120 121 122 123
  1. Transmission: Need help making a Transmission choice.
  2. Engine: Borescope
  3. Engine: Wagner Adjustable PCV Valve
  4. Body: Asbestos concerns?
  5. Frame/Springs Could somebody school me on 60's car chassis, suspension, brakes, ect
  6. Transmission: 1965 studebaker with o/d
  7. Cool/Heat: Waterways...
  8. Body: Running boards for my 37 Dictator coupe
  9. Transmission: T5 Transmission in a 1962 Lark
  10. Fuel System: 57 Golden Hawk Fuel Pump - Where does it get the boost signal?
  11. Engine: Oil
  12. Clutch/Torque Converter: Super Hawk with hill holder
  13. Fuel System: Need fuel pump for 57 Golden Hawk
  14. Body: ID fasteners please
  15. Brakes: Brake check valve
  16. Engine: Studebaker flathead 6 crate engine available.
  17. Paint: Paint Scheme
  18. Electrical: updating to 12 volt, lights
  19. Wheels Champ 8 lug wheels
  20. Engine: Temp. sender location
  21. Fuel System: Gas Gage
  22. Fuel System: Gas tank
  23. Transmission: WTB Torque converter 1547075 or 1549039 Golden Hawk and others
  24. Steering 1949 2R5 Steering Box Rework
  25. Engine: Oil pressure tube
  26. Other: Radio Mount Hardware
  27. Body: HT Vs. Sedan Roof Height
  28. Body: Lark HD Vs. Sedan Roof Height
  29. Fuel System: Help with a part number?
  30. Electrical: Need help with horn on 55 Speedster
  31. Cool/Heat: Part number heater blower motor 63/64 Hawk
  32. Wheels 72 MPH Vibriation
  33. Fuel System: Stalling and struggling idle
  34. Body: Need help with part number #285224 fitment
  35. Exhaust Manifold Gaskets that don't leak
  36. Interior: 1931 Commander Model 70? Rear window Crank Handles and Escutcheons
  37. Electrical: Back up (or reverse) lights
  38. Fuel System: Simple Green
  39. Engine: proper way to remove oil dip stick tube
  40. Engine: 1950 Commander Piston Ring Width?
  41. Cool/Heat: Need Ideas for a New Radiator in a 62 GT Hawk
  42. Other: Radio Delete Plate
  43. Cool/Heat: Restoring a Goodyear heater for 1950 Champion- ideas, opinions, speculation welcome
  44. Body: 61 champ grill, etc
  45. Paint: 61 champ
  46. Brakes: Master cylinder housings
  47. Steering Steering Shaft Removal
  48. Frame/Springs 56 Golden Hawk GT Frame
  49. Body: Door latches for "39 CE needed
  50. Transmission: 65 - 66 Floor Shift
  51. Fuel System: Fuel Pump Clearance
  52. Engine: Cost to Rebuild a 259 V-8 These Days
  53. Body: Question about mirrors, 1940 President
  54. Body: Window Run Channel
  55. Cool/Heat: What goes where?
  56. Engine: Effects of R1 cam
  57. Body: AVANTI round vs square H/L bezels
  58. Cool/Heat: A/C Bracket
  59. Body: Putting out APB for 3G Q-Body Rear Quarter Ends #274600 & #274601
  60. Other: C-Cab / Cab Mounts
  61. Body: Are these Studebaker sill plates?
  62. Frame/Springs Lark Frame Front Clip
  63. Engine: Bearings
  64. Ignition: R2 full advance mark
  65. Electrical: Lark Map Light is broken
  66. Other: removing starter from'63 Lark 6cylinder
  67. Body: '41 Body code fitment of casting #5646 trunk emblem
  68. Cool/Heat: Re-core services/ New radiators
  69. Brakes: Brake line distributor block
  70. Body: Studebaker Service Letter
  71. Frame/Springs c cab 1/2 ton truck frame
  72. Body: missing grill housing bracket
  73. Steering Quick Steering Arms
  74. Rear Axle: Ford 9 inch Vendor
  75. Steering Toe setting 85 Avanti
  76. Wheels Wheel Covers
  77. Brakes: Disk Brake conversion, 52 Champion; dominos
  78. Shocks Shock Absorber conversion
  79. Shocks Avanti coilovers
  80. Electrical: Installing an ignition switch in a '56-'61 Hawk
  81. Body: Hood locked up
  82. Engine: 259 Dyno Tests
  83. Speedo/Tach/Gauges Panal
  84. Transmission: auto trans
  85. Engine: The forensics are in...
  86. Electrical: Accessory vs Ignition , '63 Avanti
  87. Steering Steering: What Is The Spline/Size On A Hawk Steering Wheel Shaft?
  88. Electrical: Short Circuit
  89. Body: '39 Champion moulding?
  90. Engine: Spectacular Day!
  91. Other: Chicken Hawk at Indy
  92. Body: Window Rollers
  93. Body: sun roof
  94. Brakes: 1961 Emergency Brake Handle
  95. Electrical: Blinkers
  96. Transmission: Bad 1-2 shift in a FOM
  97. Interior: Head Liner
  98. Fuel System: WCFB carb versis WFB
  99. Frame/Springs 62 hawk
  100. Electrical: 1949 horn
  101. Engine: 49 champion oil leak
  102. Other: Studebaker Maintenance and repair blog
  103. Steering WTB Bell Crank
  104. Electrical: locating fuse's
  105. Steering What Year Bell Crank Steering Arms?
  106. Other: 1940 Studebaker Champion (G2) Weatherseals
  107. Body: 61-62 Champ rear cab corners
  108. Body: 60 Lark Convertible wheelhouse panel
  109. Transmission: Sluggish reverse
  110. Wheels on larks 65 66 wheels, for disc brake cars ??
  111. Brakes: Change interval?
  112. Cool/Heat: Electric Fan recommendation: 59 Lark with Chevy 350
  113. Interior: WTB 54 Commander instrument dash cluster parts
  114. Frame/Springs Frame measurements
  115. Transmission: 2/2018 - (Want to buy) - Looking For T5 Conversion Plate/Kit
  116. Fuel System: Will Carter Four Barrel WCFB specs?
  117. Steering Rack and Pinion Steering
  118. Wheels widening & reversing
  119. Clutch/Torque Converter: Diaphram Style Clutch?
  120. Cool/Heat: Overheating Issue
  121. Electrical: add reverse lights to '53 truck?
  122. Cool/Heat: 63 V8 in 59Lark
  123. Body: electroplating
  124. Shocks Bushings for a 59 Lark
  125. Ignition: MAXX products Distributor
  126. Body: mystery part
  127. Other: Transmission/Overdrive
  128. Cool/Heat: Vintage Air Install
  129. Wheels weights wait !
  130. Electrical: 6Volt Horn Repair? Need to get my '51 Champion honking!
  131. Engine: 1951 185 c.i. 6 cyl
  132. Transmission: Screw holes (for cross member)?
  133. Engine: .030 over 289
  134. Body: Avanti door latch.....
  135. Ignition: Another Distributor
  136. Interior: need temp. guage for M5 or 41 Champ
  137. Engine: overheating
  138. Engine: A knock that comes and goes???
  139. Engine: Running without tranny
  140. Engine: OHV6 valve guide height
  141. Ignition: New HEI distributor option
  142. Body: Replacing Vent Patch and Hinge & Shroud Collar Attached
  143. Rear Axle: rear axle deminsions
  144. Steering Need steering column jacket
  145. Steering power steering control valve adjustment.
  146. Engine: 1955 Cylinder Head Options
  147. Brakes: soft pedal???
  148. Fuel System: 57 Supercharged engines what carbs fit in the bonnet?
  149. Engine: A weird question...
  150. Ignition: Erratic Tach.
  151. Transmission: 1988 avanti transmission
  152. Body: truck door locks
  153. Transmission: Manual Transmission Fluid
  154. Electrical: Blinker - no blink
  155. Brakes: Ratio of use........
  156. Electrical: Avanti window motor test? Wires.
  157. Exhaust R3 headers from SI
  158. Body: Front fender mounting cushions?
  159. Paint: Looking for a source.
  160. Ignition: Ignition advance
  161. Engine: engine block number
  162. Body: Studebaker Lark doors hitting the rear edge of front fenders
  163. Electrical: How President 8 Starter Works
  164. Engine: Woe is me... again
  165. Fuel System: Electric fuel pump installation
  166. Other: Can't get my '57 Scotsman to run.
  167. Brakes: Vented Master Cylinder cap?
  168. Engine: Leak
  169. Steering Flushing the Bendix powere steering
  170. Cool/Heat: !962 Hawk Lower Radiator Hose
  171. Other: '51 Windshield Washer Accessory -- where does it go, how does it work?
  172. Cool/Heat: Removing a Silver Hawk radiator - easy??
  173. Interior: how many yds of vinyl for Lark seats?
  174. Rear Axle: what does this # mean
  175. Engine: in car oil pan removal 61 lark v8
  176. Engine: 259 v8 knock in motor
  177. Engine: 56 V8 Rocker Cover and Air Cleaner Color
  178. Transmission: Avanti II, AOD Transmission
  179. Body: Hood Release Cable Retainer Clip
  180. Cool/Heat: GT Hawk Radiator Upgrade (My Step by Step Process)
  181. Cool/Heat: 51 Studebaker Champion heater hose
  182. Brakes: having troubles after the switch from drum to discs
  183. Body: Filler
  184. Speedo/Tach/Gauges Speedo pinion gear
  185. Fuel System: Another bit to drool over...
  186. Engine: 289 +30 piston rings for single piston
  187. Interior: Restoring door panels
  188. Cool/Heat: C/K V8 Radiator Weight
  189. Fuel System: 58 Phawk gas tank leak
  190. Brakes: brakes parts color
  191. Other: Bell Crank: Cast or Forged
  192. Cool/Heat: Thermal insulation
  193. Brakes: Brake shoe relining. San Francisco Bay Area
  194. Fuel System: Electric Fuel Pump: is there a drop in the tank application?
  195. Paint: Original Paint on a 1950 Commander ??
  196. Body: dissasembly of 50 truck outside door handle
  197. Cool/Heat: AC1-80 defroster valve
  198. Cool/Heat: Clamps clamps and more clamps
  199. Steering Power steering or not.
  200. Engine: Mystery crankshaft
  201. Transmission: DG 200 250 torque converter ID
  202. Fuel System: Fuel pump leak
  203. Engine: Intermittent hesitation
  204. Cool/Heat: How far into the fan shroud should the fan be?
  205. Electrical: 1957 Golden Hawk F------in Starter Removel.
  206. Transmission: trans tunnel cover
  207. Body: Champ Vent Grill Removal
  208. Rear Axle: 64 Commander super-thick grease in the differential.
  209. Rear Axle: Reinforcing Plate
  210. Fuel System: 1955 Commander - Lifter Valley Breather???
  211. Steering A way to gain positive caster?
  212. Engine: Paint Code for 57 golden hawk engine (blue)
  213. Clutch/Torque Converter: bit by the walking clutch throw out bearing levers - looking for new (or repaired) shaft for 61V
  214. Body: Champ Pickup Floorboard replacement.
  215. Brakes: Need photo or description
  216. Steering 54 Commander drag link
  217. Rear Axle: rear oil
  218. Electrical: Alternator Bracket
  219. Ignition: 289 delco distributor
  220. Wheels Were the 1950 Studebaker Tires Tune, or Tubeless?
  221. Brakes: SS brake hoses
  222. Transmission: T 96-1B Gearbox
  223. Cool/Heat: Radiator woes
  224. Body: Champ Windows
  225. Electrical: Fuel guage sender info needed.
  226. Frame/Springs Eaton coil springs for Avanti
  227. Body: tail light gasket and screws
  228. Brakes: Add this great resource to your list(s)
  229. Rear Axle: Is there a trick to this?
  230. Electrical: 1957 Studebaker Golden Hawk looking for correct battery cables + battery
  231. Rear Axle: Thrust Block
  232. Paint: 1974 Avanti
  233. Body: A 64 Daytona Part
  234. Front Axle: 37 Coupe Express Grease seals and U joint
  235. Engine: 56 g.h. That runs fine up to 3000 rpm
  236. Electrical: Cruise ControlL
  237. Front Axle: Info needed , IFS set up
  238. Other: Cat whiskers
  239. Engine: Setting valve lash
  240. Cool/Heat: Griffin radiator for Avanti
  241. Wheels 1" white wall tires
  242. Body: panel gaps
  243. Speedo/Tach/Gauges Speedometer Lubrication
  244. Engine: V8 Block
  245. Transmission: Does anyone else have a FMX transmission in their Avanti?
  246. Brakes: Under hood remote reservoir
  247. Drive Shaft can anyone direct me to replacment, or dimensions, of this '57 spline driveshaft seal?
  248. Cool/Heat: 1940 Commander Radiator Hose
  249. Brakes: Brake Shoes
  250. Body: (Pic Request) 1959 Hawk Hood Hinge Springs
