View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 [113] 114 115 116
  1. Speedo/Tach/Gauges How does the Tach work on a 55 Speedster
  2. Drive Shaft Drive Line Angles
  3. Electrical: Ignition coil differences
  4. Engine: stuck valves
  5. Electrical: 1983 Avanti Wiring Woes
  6. Engine: R-3 Engine Size
  7. Steering Nothing is sounding good
  8. Engine: Harmonic Balancer Puller for 352
  9. Body: 42 President 8
  10. Body: 1962 VIN plate change over ? Wording
  11. Electrical: Power antennas
  12. Other: 50 & 51 Bullet Nose Champions
  13. Brakes: Disc brake pad model interchange Avanti plus..............
  14. Body: 54 Commander
  15. Fuel System: Golden Hawk air cleaner
  16. Brakes: Buying Wheel.Cylinders For 59 Silver Hawk. Need Help
  17. Steering Ford Type "F"
  18. Brakes: 1990s Vintage Turner Disc Brake Components
  19. Cool/Heat: climatizer deflector
  20. Fuel System: Reclocking Carter super pump
  21. Body: Expertise on replacing Classic Enterprise pillar base support
  22. Engine: V8 removal from '63 Lark
  23. Engine: Balancing An Entire Short Block
  24. Steering Steering wheel issue 1942 Commander
  25. Brakes: Brake question
  26. Engine: 169 engine plugs
  27. Brakes: brakes & bumpers 1955 E7 truck
  28. Frame/Springs Frame swap
  29. Electrical: Head Light Switch Fuse
  30. Body: Revolting Wagonaire development: Window Won't Move
  31. Exhaust Avanti stainless steel exhaust and mufflers
  32. Fuel System: Think tank time.........
  33. Brakes: Pads and drum linings........
  34. Engine: Flat six oil pump priming
  35. Transmission: trans rebuild
  36. Fuel System: Stupid fuel question
  37. Steering Steering wheel spline count specs
  38. Body: Installing trim on 59 Lark wagon
  39. Body: Panel Delivery Template
  40. Cool/Heat: Overheatng
  41. Electrical: Spark Plugs.....
  42. Transmission: 61 Lark losing transmission fluid
  43. Body: Need a measurement
  44. Engine: Avanti R2 manifold
  45. Speedo/Tach/Gauges Gauges
  46. Body: Removing windshield and rear glass
  47. Transmission: Trans fluid check----- 63 Flightomatic
  48. Engine: New HEI distributor
  49. Electrical: Damage by putting 12 volt battery on 6 volt system.
  50. Interior: Dash Vinyl
  51. Engine: Sealer On Valve Cover Gasket?
  52. Fuel System: gas squirting out accelerator pump shaft under boost
  53. Frame/Springs batwing?
  54. Transmission: Swapping 3 on the tree for a stock automatic in a wagonaire
  55. Interior: Looking For 1959 Silver Hawk Clock & Push Button Radio
  56. Engine: Silver Hawk: freeze plug fell out, no cracked block (so far)
  57. Electrical: Radio Install 49 Champion Missing Under Dash Mounts For J-Clips
  58. Engine: Need Champion .005" oversize valve lifters. Anyone have a set?
  59. Electrical: Electrical questions.
  60. Engine: Rear Main Oil Seal R&R, '55 Studebaker President, 259 V8
  61. Electrical: Wiper woes
  62. Electrical: Wiper woes
  63. Body: 63 Champ Gas Tank
  64. Steering how do I remove center horn button and ring
  65. Fuel System: Paxton SN 60 Supercharger 'Clocking' Parts needed
  66. Engine: Another day, another problem to work through: engine runs rough.
  67. Brakes: Front brakes, 1951 Champion
  68. Fuel System: "To use, or Not to use"
  69. Electrical: Generator, quickie troubleshooting?
  70. Body: Removing door sill
  71. Electrical: Negative battery cable connection
  72. Transmission: Flightomatic leaks BAD
  73. Ignition: Quick Question: Studebaker V8 distributor rotation...
  74. Ignition: Generator to alternator conversion burning points?
  75. Rear Axle: Pinion seal
  76. Engine: Factory mounts for a SBC?
  77. Brakes: Bypass Hill Holder
  78. Brakes: 11" Drum Swap, Front To Rear
  79. Interior: Radio Install 1949 Champion
  80. Electrical: Starter on '49 Commander
  81. Electrical: Starter on '49 Commander
  82. Wheels Tire question?
  83. Engine: Frost plug
  84. Ignition: I Did It!!! - Stabbed the Distributor into the Power Hawk...
  85. Engine: 1925 Big 6 Engine Oil
  86. Brakes: Foot Operated Parking Brake Mechanism Replacement
  87. Speedo/Tach/Gauges Remove Avanti Tach Sending Unit
  88. Rear Axle: Lube time??
  89. Body: 54 C body hood hinges. Washers or no washers?
  90. Electrical: Battery Cable Routing
  91. Speedo/Tach/Gauges 57 GH vacuum boost gauge connection
  92. Front Axle: upper A arm mount
  93. Interior: 54 Commander clock
  94. Front Axle: Industrial Chassis Inc
  95. Electrical: No Instrument lights on 62 Hawk
  96. Electrical: 6 Volt Flasher Question
  97. Body: hood hinges
  98. Clutch/Torque Converter: Replacing Clutch
  99. Electrical: 1951 Turn Signal Instructions
  100. Body: Decoding 60 Lark body tag
  101. Fuel System: Recommendations for a Good Carburetor Rebuilder
  102. Electrical: TAchometer/electronic ignition.
  103. Body: Champ window regulator
  104. Ignition: 62 GT Hawk: Cranks, fires, and dies
  105. Fuel System: Carter Fuel Pump Rebuild
  106. Brakes: Remote Fluid Reservoir
  107. Frame/Springs how much does a Champ chassis weigh?
  108. Electrical: Lark Radio install
  109. Other: Need help with a 1959 Lark
  110. Transmission: Automatic Trans Linkage Needed
  111. Speedo/Tach/Gauges Temp Sender '53 vs '56
  112. Fuel System: WCFB model numbers?
  113. Electrical: 62-63 radio
  114. Body: 1960 Hawk suggestions
  115. Paint: paint
  116. Electrical: Horn Contact Plate Removal
  117. Wheels Radial tires
  118. Electrical: Porche Tach
  119. Fuel System: How much fuel pressure is to much?
  120. Transmission: DG-200 leaks badly What is the likely problem?
  121. Body: Window channel replacement
  122. Ignition: 57 Golden Hawk distributor rotor construction
  123. Transmission: automatic transmission with over drive in a 1964 cruiser
  124. Electrical: Mechanical brake light switch
  125. Transmission: Looking for an R10 overdrive case....
  126. Cool/Heat: removing control for heater
  127. Transmission: TH700R4 OD problem
  128. Steering Passenger Car Spindle Size 1952-1964 and Bearing Differences
  129. Engine: Oil pan capacity 31 Four Seasons Roadster model 80, 337 cu in flat head straight eight
  130. Brakes: Worst Ever Install Of Turner DB Kit
  131. Body: couple of chemical questions
  132. Brakes: Brake Drum Issues on 59 Silver Hawk :-/
  133. Front Axle: dropped spindles
  134. Engine: 289 in M-5
  135. Brakes: Which rear parking brake cable to order
  136. Steering Steering column through firewall seal
  137. Brakes: Just How Useful Are 11" Rear Drum Brakes?
  138. Transmission: transmission pan interchange
  139. Transmission: Overdrive engagement
  140. Rear Axle: Looking to Change Gear Ratios
  141. Engine: identifying V8 oil pumps
  142. Ignition: Bad ignition switch or??
  143. Engine: 289/259 block
  144. Other: Compressed air lines for the Studebaker garage
  145. Engine: Missing/ Hesitation
  146. Steering My power steering has gone beserk
  147. Cool/Heat: Testing OEM '63-4 Fan Clutch?
  148. Frame/Springs Help identify these parts
  149. Other: Hawk 73 mph vibration problem solved
  150. Drive Shaft Missing Stuff For Driveline
  151. Transmission: Our friend the Powerslide/glide:)
  152. Electrical: 50 Land Cruiser generator
  153. Electrical: Parking Lamp when brake is pressed (1951 Studebaker)
  154. Rear Axle: Installing Flanged Axles
  155. Engine: Does anyone make a 6-cylinder timing cover with a lip seal in it?
  156. Engine: Recent acquired
  157. Transmission: Missing Parts for Champ Overdrive
  158. Brakes: Primary & Secondary Shoe Positioning
  159. Cool/Heat: thermostat for '63 Champ 259?
  160. Ignition: Prestolite cap
  161. Engine: Champion 1948 first start after 50 years
  162. Body: 53 HT Front window track rollers
  163. Rear Axle: Are these axle shafts interchangeable?
  164. Body: rear quarter window
  165. Engine: What now? She threw a rod -- 1951 Champion
  166. Speedo/Tach/Gauges S-W tach harness
  167. Brakes: hydrovac delete?
  168. Engine: Distributor Oiler
  169. Brakes: 1950 Champion rear brakes
  170. Electrical: Electric fuel pump causing interference on AM Radio
  171. Brakes: Hill Holder Mounting
  172. Brakes: Brake pedal arm length on 57 GH
  173. Interior: Glove compartment lock - Argh
  174. Body: 53/54 C/K horn brackets painted black or body color from factory?
  175. Transmission: Transmission Fluid Question - Silver Hawk
  176. Body: Removing a door from a '53 Commander
  177. Fuel System: Golden Hawk Carburetor Float
  178. Engine: Location of #1 cylinder on distributor cap model 31
  179. Body: Replacing vent window rubber on a 55 K
  180. Fuel System: 1939 Champion with Sticking Float in carb?? (I believe)
  181. Ignition: No Spark Issue Resolved...
  182. Fuel System: Need gas cap for 1946 Champion
  183. Brakes: Rebuilding Wheel Cylinders, help!
  184. Front Axle: shouldn't cork gasket sit lower than this (KingPin bearing depth)?
  185. Transmission: 3 Speed Manual transmission locked in low gear
  186. Brakes: 63-64 Hawk GT w/disc Brakes
  187. Body: Sliding rear roof gasket replacement
  188. Brakes: replacing master cylinder
  189. Front Axle: KingPin and Knuckle "shim /clearance" setting procedure; knuckle won't sit flush on kingpin
  190. Brakes: Hawk front to rear weight bias?
  191. Ignition: USA Made?
  192. Ignition: Ballast Resister
  193. Ignition: Sometimes friends mean well, but.......................:-(
  194. Engine: Engine noise question - hammer
  195. Exhaust Exhaust manifold Removal passenger side GT Hawk
  196. Brakes: Rear brake hose
  197. Cool/Heat: Heater Hose for 1964 Daytona
  198. Interior: Steering wheel options
  199. Ignition: Prestolite Dizzy
  200. Rear Axle: Rear Axle 53 Champion
  201. Body: Split Windshield Installation Instructions
  202. Electrical: Overdrive solenoid
  203. Brakes: Power brakes without the booster?
  204. Electrical: Starter circuit
  205. Wheels Stuck lugs
  206. Body: Preserving hog troughs
  207. Steering changing steering box 50 commander
  208. Ignition: Who would know..............Prestolite IBS 4012
  209. Body: Lark Hardtop Window Adjustment questions
  210. Body: Figuring out locks on 59 Lark
  211. Ignition: DELCO Rotor Failure
  212. Engine: Arrangement of pulleys and balancer on ohv 6 with alternator and Power steering
  213. Brakes: Brake Job & "Green Stuff" Pads
  214. Front Axle: Help! Control-Arm Spreader Tool NOT doing the job on Upper Control Arm (or is it??)
  215. Other: General Restoration Questions
  216. Cool/Heat: LARK Fan Shroud Interchange
  217. Ignition: Misfitting DELCO Caps From NAPA
  218. Front Axle: Control-Arm Spreader- different location, and ears keep spreading with time; this is weird
  219. Body: I need info on glass
  220. Exhaust 1956 Power Hawk question
  221. Body: Phillips Bit For Door Hinges
  222. Engine: '83 Avanti Serpentine conversion
  223. Brakes: Brakes disappeared
  224. Rear Axle: Avanti rear axle ratio
  225. Ignition: Before I spend money needlessly:-)
  226. Engine: DIY supercharger rebuild?
  227. Fuel System: Master Mechanic Carter AFB and WCFB Jet Size and Rebuild Information
  228. Rear Axle: Best Rear Gears With OD And V8
  229. Body: Windshield for a '39 Coupe Express
  230. Brakes: Parking Brake Cable Removal
  231. Wheels Wheel interchange
  232. Cool/Heat: Water Pump
  233. Body: 57-61 Hawk question
  234. Clutch/Torque Converter: How does a broken clutch facing feel?
  235. Fuel System: Replace Stock Carb on '48?
  236. Body: 63 wagonaire tailgate. need a part!
  237. Engine: R2+ camshaft valve lash
  238. Other: A/C Dumb question time........
  239. Electrical: Light bulbs
  240. Rear Axle: Service
  241. Clutch/Torque Converter: 5E7 Clutch Problem
  242. Engine: Sump pan Leaks
  243. Body: 51 Champion rear window
  244. Body: Sedan rockers converted to Hawk?
  245. Engine: OHV valve spring compressor
  246. Wheels '64 Champ rim color...
  247. Engine: 1955 Commander - gashes found on piston heads
  248. Speedo/Tach/Gauges Avanti Repairs
  249. Ignition: For those "old timers" who might remember:-)
  250. Wheels 1962 Hawk Wheel Cover Touch Up Paint
