View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 [112] 113 114 115 116 117 118 119 120 121
  1. Ignition: Buying Ignition/door cylinders 1955 champion
  2. Brakes: Need opinions on installing dual master cylinder and Turner front discs on '64 Hawk
  3. Engine: 224 cu-in V8 rebuilt
  4. Transmission: How To Identify My Transmission?
  5. Brakes: Tips For Putting Master Cylinder Spring Back On?
  6. Interior: Speedster dashboard repair, what type of plastic?
  7. Transmission: Gear Position
  8. Engine: 40 lbs At Idle
  9. Brakes: 1955 President Sedan - Anyone Ever Install Suspended Pedals and Brake Booster?
  10. Fuel System: Electric fuel pump
  11. Fuel System: Fuel system
  12. Rear Axle: Looking for a mechanic
  13. Engine: 232/259 engine
  14. Engine: Bad #2 Cylinder?
  15. Rear Axle: Installing rear axle key on 1953
  16. Brakes: Brakes dragging
  17. Electrical: 1962 Studebaker Champ Fuse Box Location
  18. Fuel System: 6 Cyl. Fuel Pump
  19. Fuel System: Electric fuel/ do you need to adjust float level
  20. Engine: Sloppy Valves, how much is to much
  21. Electrical: Lark Headlight issues
  22. Steering O-Ring in Saginaw Power Steering hose
  23. Wheels Washers w/ Wheel Nuts???
  24. Body: Discovered rocker panel replacements in my dad's collection, what model do they fit?
  25. Electrical: 1963 Hawk Alternator needs rebuild
  26. Engine: Where'd the term "still tight" come from ?
  27. Other: Drivability Question 1949 2R5
  28. Cool/Heat: Red Cooling Hose in 1927?
  29. Engine: Is this block too rusty?
  30. Front Axle: South Bend area alignment shop
  31. Other: Need help to identify a Studebaker
  32. Frame/Springs 1966 Buick front shocks for '63 Hawk
  33. Front Axle: Upper Control arm outer mounting for bushing
  34. Engine: Oiling system plug
  35. Rear Axle: How much oil....
  36. Electrical: Wiper switch issue-'63 Champ
  37. Paint: Speedster paint and trim codes
  38. Electrical: Starter exchange on 1953 Commander
  39. Engine: Engine bearing brand
  40. Body: Bullet nose 1950 to 1951
  41. Electrical: Brake lights
  42. Electrical: headlight switch
  43. Rear Axle: Differential Pinion Seal Replacement
  44. Transmission: 1950 Champion with Automatic and Hill Holder????
  45. Interior: Still deciphering the Studebaker PO - TRIM NO. 7595 EG CL-1
  46. Front Axle: Ever tried using both early and late front anti-roll bars together?
  47. Front Axle: 4 wheel alignment 63 Hawk.
  48. Other: Depression in right front side grille
  49. Paint: Paint colur
  50. Cool/Heat: 53-55 CK electric fan
  51. Engine: Dropping the Oil Pan in a 1946 M15
  52. Engine: Replacing Engine Mounts
  53. Ignition: Distributor Conversion Choice
  54. Fuel System: 185 cid Throttle linkage Spring Question
  55. Brakes: What would you do; install freshly turned brakes on chassis that will still sit 1-2 yrs? (in MN)
  56. Electrical: Curious ammeter behavior
  57. Transmission: Transmission Dip Stick: Manual VS Automatic?
  58. Steering Down the Road
  59. Engine: 259 v8 pushrod out and won't go back
  60. Body: '63 Hawk wheel lip molding retainers
  61. Body: Replacing Rear Pan (Rear Weather Strip Channel) with Classic Enterprise repair piece 1953 C
  62. Electrical: Still havig trouble putting the headlight switch back together on my 62 GT Hawk
  63. Transmission: Studebaker Bell Housing Adapter
  64. Electrical: Blowing 14 Amp Fuse on 1951 Turn Signal Setup
  65. Steering 63 Lark. Big interference issues
  66. Electrical: Under hood Light
  67. Other: Tires/Rims for M15 Studebaker
  68. Electrical: harness routing
  69. Body: Problem with 57 GH side grilles
  70. Other: Wheels: Transmission: Rear Axle: Speed-Ratio-RPM Calculation
  71. Brakes: '56 Golden Hawk Brakes
  72. Electrical: Please tell how to change the Tell-Tale turn signals/high beam indicators
  73. Frame/Springs Looking for U-Bolts for Rear Leaf Springs on '54 Commander Land Cruiser
  74. Engine: 1949 Studebaker 2R6 Inline 6 engine Diagrams
  75. Speedo/Tach/Gauges Turn signal fix
  76. Body: Fender Well Trim
  77. Engine: Oil & Lubricants for Classic Cars
  78. Steering steering box ( power steering too)
  79. Transmission: Lark/Hawk 4-speed Boot Retainer Positioning?
  80. Other: Studebaker identification
  81. Transmission: 3 speed w/OD
  82. Body: 1938 commander door adjustment
  83. Other: '56 Goldem Hawk at Gateway
  84. Brakes: Are these new Brake Springs going to work (57GHawk), or too tight? See photos, thanks!
  85. Engine: Size of Bolt for Crankshaft - 1959 Lark V8
  86. Cool/Heat: 1955 Commander - Draining the Cooling System
  87. Body: WTB: Tail Light, Hood Trim
  88. Brakes: Wheel Cylinders (new but 6 years sitting in basement); Discoloration (corrosion) started; replace?
  89. Electrical: Energy to brake lights
  90. Transmission: towing
  91. Electrical: 6volt and 12 volt converter
  92. Engine: Off topic(?) intake manifold question...
  93. Brakes: What lubricant is on new Wheel Cylinders (brakes) ??? How can it be compatible with brake fluid?
  94. Interior: GH interior rear panel removal
  95. Transmission: Transmission Identification?
  96. Body: 1964 Lark Type Rear Window Adjustment
  97. Transmission: 1950 Champion Transmission - Engine Braking?
  98. Other: '51 Champion -- Hi Tone Horn needed!
  99. Body: Need help removing trim from 53 Regal
  100. Transmission: More hodge-podging with overdrives
  101. Speedo/Tach/Gauges Gauge Removal
  102. Rear Axle: Axle nut
  103. Transmission: Over drive
  104. Engine: Oil Filter 1962 Lark Taxi 6cy
  105. Electrical: generator
  106. Electrical: harness routing
  107. Transmission: 4 spd oil for R2 Avanti
  108. Body: Removal of duct between vent and interior on '50
  109. Transmission: Identifying bell-housings.
  110. Transmission: Shifting problems: '51 Champion
  111. Wheels What wheels?
  112. Other: Sky Hawk Progress
  113. Electrical: Ignition resistor
  114. Body: WHERE Does The Prop Rod Go!
  115. Frame/Springs Bushings for '56 3/4 TN heavy duty rear leaf springs
  116. Body: AC-3306/07 Splash guard installation instructions
  117. Fuel System: Fuel Pumps, Fuel Pumps, Fuel Pumps for V8
  118. Fuel System: Tech: Cleaning Carb in Pine-Sol
  119. Drive Shaft Driveshaft yokes
  120. Brakes: Caliper grease on brake shoe pushrods?
  121. Cool/Heat: Fan
  122. Engine: Starter
  123. Body: Stainless Steel Molding around Hawk G.T. windshield
  124. Steering M5 Ross TA steering box repair
  125. Engine: Ye olde valve rocker arm adjustment problems- 1955 259 V8, Presiident State
  126. Rear Axle: rear drum removal 54 champion coupe
  127. Transmission: wiring a Borg warner od Transmission
  128. Brakes: Sky Hawk Drums
  129. Brakes: Disc Brake Kits
  130. Interior: Avanti Carpet Images or Pictures.
  131. Fuel System: No vacuum in stromberg ww auto choke housing
  132. Transmission: Second gear start automatics
  133. Rear Axle: rear axle seal replacement
  134. Electrical: 2r5 Horn
  135. Ignition: dwell time in degrees on Pertronix ignition.
  136. Front Axle: To flip or not to flip
  137. Ignition: Ignition switch woes
  138. Ignition: '63 Avanti-- no electrics; won't start, no lights
  139. Rear Axle: found in rear end ?
  140. Steering Steering shaft diameter
  141. Engine: oil light
  142. Ignition: Wiring issue
  143. Body: Trunk lid insulation 64-5-6
  144. Drive Shaft Unbalanced Driveshaft
  145. Electrical: Champ wiper motor
  146. Other: General engine bay cleaning
  147. Electrical: Passenger turn signals
  148. Engine: New member's engine ID question
  149. Electrical: exploded view of 62 GT headlight switch
  150. Other: Hood support piece
  151. Transmission: Auto trans for '63 Lark
  152. Cool/Heat: Radiator dimension for a 58 Studebaker Champion
  153. Brakes: 57 GH master cylinder/hydrovac question
  154. Engine: Repairing Crankshaft with bad connecting rod journal
  155. Steering GT Hawk '63 Tie Rod Orientation
  156. Electrical: 56J Spark Modifier
  157. Frame/Springs Hawk frames
  158. Transmission: transmission mechanics in new mexico
  159. Engine: 259 Engine 'shudders'
  160. Steering Thread Seal Tape?
  161. Cool/Heat: 1964 sedan, cruiser
  162. Transmission: 200 4R Mystery!
  163. Brakes: Front Drum vs. Front Disc
  164. Brakes: 84 Avanti wheel bearing spacer
  165. Electrical: Avanti taillights leads
  166. Fuel System: Need Gas Tank for 62 Champ Truck
  167. Steering '63 Avanti PS Unit Needed
  168. Steering Bellcrank Wear
  169. Transmission: Flight-o-Matic Question
  170. Frame/Springs Lube inner control arm busgings
  171. Body: Rechrome Avanti bumpers
  172. Body: Help identifying 57 GH weatherstrip piece
  173. Electrical: Wiring and turn signal cam in steering column 54 Commander
  174. Body: 59-62 hardtop door frame dimensions
  175. Body: Champ Cab Mounts
  176. Fuel System: best source for 75 avanti II fuel tank
  177. Clutch/Torque Converter: 1940 broke clutch linkage
  178. Body: What are these?
  179. Frame/Springs Which way is up?
  180. Body: Removing window trim
  181. Engine: Connecting rod size
  182. Ignition: Coil cross-reference needed
  183. Body: 41-42-46 Door weatherstrip orientation??
  184. Body: Hood won't Pop open
  185. Body: 56 Hawk Lower Hood Stainless Trim?
  186. Electrical: 1950 Studebaker turn signal light(s) in dash
  187. Other: 1962 Lark Regal Convertible - 6 Cylinder Production
  188. Body: Window rubber
  189. Transmission: Overdrive Transmission for 1949 2R5
  190. Cool/Heat: Air Condition Dual Pully for 50 Land cruiser
  191. Engine: In over my head!
  192. Engine: engine stand advice needed for bare 289
  193. Cool/Heat: 1965 Cruiser cooling problem?
  194. Fuel System: Gas Gauge
  195. Cool/Heat: Hawk AC related overheating resolved
  196. Brakes: 64 hawk brake fluid reservoir
  197. Wheels Ford 15" Interchange Question
  198. Transmission: swapping a T5 transmission in a 1955 E7 pickup
  199. Brakes: "Hot Rods and Brakes" Disc Brake Kit SUCCESS +!
  200. Fuel System: I need help..........2 barrel Stromberg Carburator, and brake question.
  201. Transmission: Flightomatic rear extension housing seal
  202. Cool/Heat: 51 Land Cruiser heater hose
  203. Electrical: Where to attach 6 volt + ground battery cable
  204. Transmission: what are the specs of a 1543775 Powershift transmission lever.
  205. Frame/Springs 1956 Hawk coil springs
  206. Body: 2R5 Body Removal
  207. Ignition: Delco Remy Distributor 1110969
  208. Body: 53 Champion Hardtop K-BODY
  209. Engine: engine
  210. Brakes: DOT 4 fluid is silicone?
  211. Cool/Heat: Temp gauge or sender?
  212. Front Axle: With COMPLETE bare frame, what sequence would you recommend for assembly of front end?
  213. Electrical: Power window switch
  214. Paint: 51 Land Cruiser inner fender color
  215. Brakes: UPDATE: Hawk Brakes completed, and warning on NEW US-made cylinders
  216. Other: Broken Bolt Removal from Cylinder Head
  217. Fuel System: Locking Gascap for 59 lLark?
  218. Body: 57 GH window stop bracket
  219. Clutch/Torque Converter: Pilot bearing R&R
  220. Engine: Prep Engine Block Deck and Cylinder Head Mating Surfaces for New Gasket
  221. Clutch/Torque Converter: Pilot bearing R&R
  222. Fuel System: 1955 Champion caburetor diaphragm
  223. Other: Iowa City-Coralville Area
  224. Frame/Springs frame thickness
  225. Engine: Enlarging the oil drainback holes in '55-61 heads to the '61-64 diameter - benefits and dangers
  226. Electrical: Horns
  227. Engine: 6volt to 12volt starter where do i get one
  228. Engine: Engine swap out 52 Champion
  229. Body: 53 "K" rear quarter window install.
  230. Engine: 1950 land cruiser starter
  231. Engine: motor swap 185/170
  232. Frame/Springs Lark Rear Engine support cross member. replacement plan
  233. Brakes: 56J Power Brake Booster
  234. Fuel System: AFB Carbs
  235. Frame/Springs Avanti frame rust, where to check?
  236. Body: GT Hawk Decklid Antenna Hole Pattern Template
  237. Other: Delrin Bushings
  238. Steering 53 Commander Steering Arm Removal
  239. Interior: Removing the compartment light cover - 1955 Champion.
  240. Electrical: Problems with the directional switch
  241. Transmission: Lark transmission cooler?
  242. Frame/Springs any benefit to this steel ring under front coils? (57GHawk)
  243. Wheels Allowable wheel runout
  244. Ignition: 1963 6 cylinder distributor
  245. Brakes: How is the Parking Brake cable housing "attached" to the rear backing plates?? ( '57 GHawk)
  246. Body: door hinge
  247. Fuel System: Carburetor info needed
  248. Engine: Cleaning Rocker Arm Shaft Bores
  249. Engine: need help identifying engine
  250. Paint: paint code lookup
