View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 [111] 112 113 114 115 116
  1. Body: Window gaps
  2. Body: window regulator: window falls down
  3. Fuel System: Carter fuel pump
  4. Engine: The " other " 259........
  5. Engine: Turbo for Stude V8 FS
  6. Drive Shaft Question about replacing my center bearing
  7. Ignition: Sticky key
  8. Electrical: Changing the spark plugs leads on a 185 cid 6 cyl.
  9. Clutch/Torque Converter: more clutch talk
  10. Engine: "micro jerking" at highway speed
  11. Frame/Springs Front coil springs
  12. Body: 57 GH Rear Window reveal Clips
  13. Engine: Checking on getting the correct valve stem seals for 259
  14. Engine: Replace valveseals with heads on engine...
  15. Brakes: 1955 Commander - Brake Reservoir Trouble
  16. Brakes: 64 Champ rear shoes
  17. Engine: 1955 185 cid 6 cyl Oil Filter help
  18. Wheels 1939 Champion bouncing down the road.
  19. Brakes: Disc Brake Conversion Question - Wilwood
  20. Body: Avanti emblems
  21. Paint: 55 Speedster Engine Bay
  22. Rear Axle: Send Out Dif, Or Attempt To Look Into Myself?
  23. Frame/Springs 1960 Lark Leaf Springs
  24. Cool/Heat: double sided socket?
  25. Cool/Heat: SI "NEW" radiator 802182
  26. Engine: Oil drain plug threads
  27. Engine: 1949 2R5 Drive Notes
  28. Transmission: Conversion of 1935 Dictator tranny to OD
  29. Rear Axle: '40 Champ
  30. Body: Sky Hawk Trunk Lid
  31. Transmission: 1961 Lark Shifting
  32. Other: Windshield Wiper Blades and Arms
  33. Shocks Monroe shocks
  34. Rear Axle: Dana 44 Stude axle
  35. Interior: '47 - '50 Two Piece Windshield Installation
  36. Cool/Heat: 1961 Hawk & Lark fan blade color!?!?
  37. Body: 2R Truck Door Window Guide
  38. Engine: 2R 170 Thermostat
  39. Body: Door molding
  40. Electrical: How do I bench test a 4 wire Power Window Motor?
  41. Electrical: LED bulb options for a 6 volt positive system
  42. Fuel System: Fuel pump question 1964 GT Hawk
  43. Body: '62 Hawk trim removal (How to?)
  44. Electrical: Fuel Gauge converter
  45. Fuel System: carter AFB
  46. Body: 62 GT Upper Door Weatherstrip
  47. Interior: Avanti custom autosound stereo.
  48. Body: Hawk missing window part?
  49. Transmission: Putting Power shifter together
  50. Transmission: Any tips for installing a manual transmission?
  51. Ignition: V8 Distributor Install... 1956 Power Hawk
  52. Engine: Hard to start 170 L head 6
  53. Body: 1958 Starlight coupe quarter panel removal
  54. Frame/Springs Springs
  55. Engine: Oil drain plug leak
  56. Electrical: Turn signals. 1949 Champion.
  57. Body: Lowes "Peel & Seal"
  58. Body: Window stops
  59. Speedo/Tach/Gauges Restoration service for gauges and clocks
  60. Clutch/Torque Converter: Flightomatic Torque Converter Ring Gear
  61. Ignition: Points fried to nothing.
  62. Body: Avanti Hood Springs Needed
  63. Transmission: Flight-O-Matic Selector Shaft Seal
  64. Body: Just confirming; all '57-61 Hawk fins are steel - right?
  65. Fuel System: 6v fuel sender
  66. Electrical: One wire alternator
  67. Ignition: Anyone experience a Mallory distributor failure?
  68. Body: 59 Lark wagon Back up Lights
  69. Engine: What motor came in this 54 coupe?
  70. Fuel System: 1950 Commander Air Cleaner and license frame
  71. Rear Axle: Stuck axle
  72. Ignition: V8 Tune Up Parts
  73. Brakes: M 15 wheel cylinders
  74. Exhaust 259 Cracked Exhaust Manifold
  75. Other: Turn signal adjustment
  76. Engine: Oil filter restriction fitting
  77. Engine: good Stude mechanic in Denver, CO??
  78. Clutch/Torque Converter: Vibration
  79. Engine: NEW TIMING GEAR install advice needed for SPECIAL 6 , RE: piston valves , marks etc.
  80. Transmission: Hard to shift from first to second.
  81. Engine: 57 GH Valve cover color
  82. Electrical: 56J Golden Hawk turn signal switch
  83. Engine: best cylinder lubricant
  84. Rear Axle: Replacement rear end for '62 Hawk
  85. Transmission: -58 auto-trans in -57 sedan
  86. Other: Electric Windshield Setup Recommendation
  87. Fuel System: 64 Avanti Runs Fine, then quits, starting fluid re-start?
  88. Fuel System: Oil Bath filter clog !
  89. Electrical: Electrical connectors
  90. Body: Opening the Clock Mounting Hole
  91. Fuel System: 1950 Commander Air Cleaner Parts Wanted
  92. Body: Align Driver's Door
  93. Engine: NEW TIMING GEAR install advice needed for SPECIAL 6 , RE: piston valves , marks etc.
  94. Body: Windshield Install on a '51
  95. Engine: Oil Pressure Relief Valve - Help where is it?
  96. Frame/Springs frame and axle paint colors
  97. Electrical: Question about 1950 accessory warning light
  98. Fuel System: R1's running the Edelbrock 1403 Carburetor Jets?
  99. Cool/Heat: Heater Core Overhaul
  100. Other: nuts and bolts
  101. Body: headliner installation
  102. Fuel System: '57-58 Supercharger Air Box
  103. Engine: 283 Harmonic Balancer
  104. Engine: What is your choice of engine oil in a stude V8 ??
  105. Engine: modern build practices
  106. Other: 1959 Silver Hawk. Power Steering & Automatic Conversion Help
  107. Brakes: Commander wheel cylinders
  108. Engine: Big trouble
  109. Steering Power steering control valve.
  110. Electrical: 1963 Hawk fender indicator bucket
  111. Body: 63 GT inner fender
  112. Engine: 259 crank in a 232?
  113. Interior: Very RARE Part Needed (Vintage Speaker Grill)
  114. Fuel System: Fuel Pump Identification-Hawk '63
  115. Steering Power steering Kit - 6 Cyl.
  116. Wheels 16" wheels?
  117. Electrical: Broken ign. switch wires
  118. Fuel System: Daytona WW carb
  119. Electrical: Radio Power Wire
  120. Electrical: 6 volt To 12 volt conversation Kit
  121. Electrical: 1962 Hawk Wiper Switch
  122. Steering Tie Rod Bolts
  123. Electrical: 63 Hawk horn wiring
  124. Steering I need some pictures (AND A PART) of the Saginaw power steering unit used from 1953 to 1957(?)
  125. Engine: Engine seized when hot
  126. Engine: 53 Commander Oil filter options?
  127. Engine: Broken Crankshaft
  128. Transmission: Hard to get Avanti out of reverse
  129. Exhaust Sky Hawk Exhaust Parts Numbers
  130. Steering Control Valve
  131. Engine: Front engine noise 259 Transtar
  132. Rear Axle: Differental gears
  133. Body: How to install glass in a 49 business coupe?
  134. Engine: ROLLER CAM - Projects and updates 2017
  135. Body: windshield & seat
  136. Wheels '61 Champ - want aftermarket wheels
  137. Electrical: Breaker points to electronic
  138. Electrical: GT Hawk dash grounding
  139. Engine: Isky st-6 cam info
  140. Steering Recommened Settings for Front End Alignment
  141. Body: Looking for for part
  142. Brakes: Hill Holder "dragging"
  143. Engine: identifying my 59 Lark engine
  144. Engine: 259 V8 with clutch, and bell housing/ FREE
  145. Body: Looking for hawk door glass parts
  146. Body: '83 Avanti Rear Lid
  147. Fuel System: WE Carburetor
  148. Cool/Heat: Radiator Difference
  149. Body: Windshield Washer Bag
  150. Brakes: Disk brake rotor thickness?
  151. Speedo/Tach/Gauges Growling Speedo
  152. Steering 1936 Studebaker banjo wheel
  153. Body: Need help fixing new rear fenders damaged in shipping
  154. Transmission: Need info on changing 63 Flight-o-matic to 1rst gear start
  155. Engine: 51 Land Cruiser fan blade color
  156. Engine: 352 oil pump Hudson/Nash
  157. Engine: 1955 Commander: intake removal
  158. Steering Lark power steering on 51 commander
  159. Body: bucket seat 63-66
  160. Transmission: 62 hawk GT Transmission issues
  161. Engine: Rear engine mounts on 57 Golden hawk
  162. Steering TW issue lark Saginaw in C K
  163. Brakes: Master cylinder removal 1956 president
  164. Brakes: Brake pad material
  165. Other: 54 Starlight Commander new purchase
  166. Transmission: overdrive works, but not on hot days
  167. Body: Question: Fin Attachment 57-58 Hawks
  168. Engine: Interesting substitute for ZDDP with Jay Leno
  169. Fuel System: non-ethanol fuel for a few of us
  170. Other: How to access Tech Tips back to 2012? esp door pillar repairs
  171. Engine: Oil pressure drops when engine is warmed up 40 Champion flat 6
  172. Fuel System: Fuel to the Carb
  173. Interior: Searching for '27 Dictator interior door handle
  174. Transmission: Swap Transmission From 60 Lark to 59 Hawk?
  175. Ignition: Does Anyone Make A Delco HEI Distributor For A Stude V8 ??
  176. Engine: Air Cleaner Left or Right-which way is right?
  177. Steering power steering pump
  178. Body: 56j trunk latch
  179. Fuel System: Mr. Gasket electric fuel pump failure.
  180. Fuel System: 64 Avanti Air Filter supply hose.
  181. Ignition: Want To Buy a Delco Widow Distributor
  182. Body: Patch panels for rear of front fenders
  183. Clutch/Torque Converter: I need help to identify a bellhousing
  184. Shocks '63 Hawk rear shocks for sale
  185. Interior: Adding rear seat belts on '63 Hawk
  186. Fuel System: need a fuel pump
  187. Paint: 1950 Champion Bullet Lettering
  188. Ignition: how to hot wire
  189. Interior: 1957 golden hawk headliner
  190. Body: Parts/trim needs. And some questions re:54 Starlight.
  191. Engine: Superchargers available in 1957-58
  192. Interior: "Hard" carpets
  193. Rear Axle: How To Tell Which Hawk Rear Axle I Have? 44 or 23/27?
  194. Body: Convertible Top Interchange
  195. Electrical: 1955 Champion converting to LED lights
  196. Electrical: 1955 Champion converting 6 volts to 12 volts "Waste of money?"
  197. Body: "U" Clip Bolts
  198. Ignition: Ignition frustration
  199. Engine: Ellis Duo Carb Setup
  200. Brakes: 56 Power Hawk Brake Drums
  201. Electrical: '61 Hawk ammeter gauge reading high
  202. Engine: Connecting rod bearing sizing
  203. Cool/Heat: Is My Radiator CROOKED?
  204. Body: compare 54 champion to Hawk
  205. Exhaust Mystery 57GH Exhaust{?} Part
  206. Interior: Where can I get thesholds for my 58 Siverhawk ??
  207. Electrical: Starter problems
  208. Brakes: Is it possible to retain the hill holder when converting to a dual chamber master cylinder?
  209. Body: 63 Hawk windows
  210. Engine: Intake manifold
  211. Electrical: Switching to 12V - change the battery box?
  212. Fuel System: Just gasket problems?
  213. Fuel System: Fuel Pump
  214. Fuel System: Carb Adjustment
  215. Other: Zerk fittings...
  216. Brakes: superhawk brake question
  217. Brakes: Disc Brake Proportioning Valve
  218. Clutch/Torque Converter: Throughuot Anti-Rattle?
  219. Engine: Grenaded enginge! i like the term if fits.
  220. Electrical: cable for trunk mount battery
  221. Engine: Oil Leak Stop Products
  222. Cool/Heat: Water Pump Impeller To Housing Design Clearance
  223. Rear Axle: Who's differential....
  224. Speedo/Tach/Gauges Tach hanging up
  225. Body: No driver's side door lock on '46 Champ coupe??
  226. Shocks How tight should shock bolts be (rear57 GHawk)?
  227. Cool/Heat: Radiator Information Needed
  228. Engine: Spun bearings
  229. Steering power vs manual steering belcrank
  230. Engine: Sky Hawk 289 Success...Finally
  231. Other: New GT Ownef
  232. Fuel System: fuel pump
  233. Transmission: T86 not engaging reverse or first
  234. Engine: Connecting Rod confusion
  235. Interior: What do the backs of 61 Hawk seats look like?
  236. Transmission: 4sp bellhousing
  237. Brakes: strange disk brake rebuild issue - locked piston
  238. Paint: color confusion
  239. Engine: Draft Tube
  240. Interior: Avanti Maroon versus '64 Lark-type 'Red' Interior Colors?
  241. Steering Can you over torque the Bell crank?
  242. Electrical: 1953 2R6: 12V (-) ground...Tail, stop & directional wiring ??
  243. Transmission: transmission modulater
  244. Brakes: Need Wheels For Turner Disc Brakes
  245. Wheels !6" Wheel Shells
  246. Wheels 57GH Wheel Color
  247. Body: 1964-5-6 Rocker Panels
  248. Body: 74 Avanti Front and Rear Windscreen Installed.
  249. Ignition: Buying Ignition/door cylinders
  250. Ignition: Buying Ignition/door cylinders 1955 champion
