View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 [110] 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Body: What is This???
  2. Steering steering bell crank
  3. Clutch/Torque Converter: '63 lark clutch replacement
  4. Body: Door hinge access
  5. Engine: how to build a studebaker v8 for optimal efficiency?
  6. Rear Axle: 1940 Commander - Rear wheels stuck
  7. Ignition: 1950 Champion- I need a distributor cap "retainer spring and support"
  8. Engine: Small Block Conversion Prices and Pitfalls - Champ truck
  9. Brakes: Hydrovac rebuild update
  10. Body: 51 pick-up door latch torsion springs
  11. Other: K-body window rollers
  12. Fuel System: 45 Year Old Gas in Tank
  13. Fuel System: Dashpot Missing...
  14. Engine: Removal Of Oil Pan on 57 Packard
  15. Wheels what wheels do I need for a 55 c body 2 door president?
  16. Electrical: Float Charging Battery
  17. Transmission: Weight of powershift transmission?
  18. Engine: Rear main seal replacement question
  19. Brakes: Parts to rebuild hydrovac?
  20. Rear Axle: Hawk axle Raitos
  21. Ignition: Replace 2 piece distributor - 52 Commander
  22. Wheels What does this hubcap fit?
  23. Engine: Cylinder Head
  24. Other: What is the typical top end speed for a '63 R1 Avanti
  25. Engine: Hawk fan upgrades
  26. Rear Axle: Rear sway bar at rest
  27. Interior: 66 Commander Interior color
  28. Engine: V8 Rear Seal... Is This for Real???
  29. Engine: What determines?
  30. Engine: Got my 1963 259 block and heads back from the machine shop
  31. Wheels tire sizes
  32. Transmission: OD Trans stays in overdrive all the time the lever is pushed in
  33. Frame/Springs Champ Truck Lowering Question
  34. Engine: 50 VS 51 Champion
  35. Interior: My first carpet installation; I need your advice!!
  36. Body: 53-61 C&K back window-made in Taiwan
  37. Brakes: weepy washers
  38. Transmission: Basically the same as our Flightomatics....
  39. Engine: 63 avanti
  40. Engine: Oil System
  41. Transmission: DG transmission question
  42. Brakes: 1960 Lark 6 cyl frt brake
  43. Electrical: radio
  44. Speedo/Tach/Gauges Super simple question: changing a bulb
  45. Other: Location of serial number
  46. Electrical: Test run Electrical
  47. Transmission: 1951 Champion transmission options/info
  48. Fuel System: Edelbrock 1403 - best power source for the choke?
  49. Cool/Heat: 74 Avanti Heater Probe Location
  50. Brakes: 1949 2R5 E-Brake Help Needed
  51. Body: FS: rechromed front bumper coupe/hawk
  52. Front Axle: Mounting a heavy duty front stabilizer bar on a Hawk
  53. Electrical: Where is the ground located in 53 Starliner Commander?
  54. Engine: 170 OHV head ID
  55. Brakes: Weepy washers problem solved
  56. Transmission: Quick Question Regarding Weight (DG-150)
  57. Engine: Supercharger operation
  58. Brakes: brake shoes
  59. Brakes: gasket prep?
  60. Electrical: Before I changed the oil, my car ran great-- now I can't get engine to crank? How to troubleshoot?
  61. Electrical: reasons to not convert to 12 volts
  62. Engine: 289 block
  63. Fuel System: What's going on with this spring?
  64. Other: 2R5-12
  65. Fuel System: Neg. ground 6v. flow-thru pump?
  66. Engine: Studebaker champion 1984. The Car smoking
  67. Cool/Heat: 64 Hawk Climatizer housing diagram?
  68. Electrical: 57 Packard switch removal
  69. Interior: 1958 Transtar interior installation instruction or photos
  70. Brakes: Mechanical brake switch GT ??
  71. Wheels Widest tire size for 6" rims?
  72. Front Axle: Thoughts on rubber bushing for Avanti rebuild
  73. Engine: 289 rod bolts
  74. Electrical: LED's & Turn Signals
  75. Frame/Springs 51 Champion Frame dimensions
  76. Exhaust Heat Riser Valve Proper Function
  77. Electrical: Gremlins?
  78. Wheels Tire Changing (machine)
  79. Engine: Self Loosening Bolts
  80. Body: Door window
  81. Rear Axle: diff. ID 64 hawk
  82. Engine: disassembling seized engine, pistons wont move
  83. Fuel System: PART 2: Edelbrock 1403 Conversion on 1963 R1 Avanti
  84. Body: GT Hawk trunk overlay
  85. Electrical: 1950 radio
  86. Transmission: How much would you do to freshen up a transmission?
  87. Cool/Heat: 49 champion starlite coupe
  88. Electrical: Best battery connections ?? (12V positive ground to 12V negative ground...)
  89. Engine: 259 cu in Oil System
  90. Interior: '55 President steering wheel - what is the top color?
  91. Interior: 63 Wagonaire reinforcement to the roof panel
  92. Engine: CNC Heads For Stude V8's Now Available - See Them At South Bend 2017
  93. Electrical: Avanti underhood light
  94. Electrical: wire cable Pt. # 1560412
  95. Other: Anco Deadlocker Windshield Wiper Arm Install
  96. Transmission: Need part
  97. Other: Wiper Repair - '50 Champion
  98. Steering Adjusting new steering gear
  99. Electrical: Screwed up something ! 12V (+) ground to (-) ground smoking generator..!
  100. Steering 53 Commander steering/turning radius
  101. Electrical: My Heater Fan Switch Is Trying To Kill Me
  102. Engine: 61 Champ V8 259/ hasn't run in 20 years
  103. Engine: 61 Champ V8 259/ hasn't run in 20 years
  104. Engine: Dyno results
  105. Interior: Seat mount
  106. Body: Rear Vent Window Moulding
  107. Transmission: Lsrk 6 manual trans O/D question
  108. Fuel System: No constant fuel pressure
  109. Frame/Springs Leaf spring bushings
  110. Transmission: Does a '63 Avanti Automatic Transmission share the transmission oil pan with any other automatics?
  111. Speedo/Tach/Gauges Oil Gauge; how much credibility?
  112. Interior: Champ or T-Cab Seat Track Question
  113. Body: Hinge L/H or R/H
  114. Body: front fenders GT hawk for sale
  115. Window channel substitute?
  116. Speedo/Tach/Gauges 1957 President speedometer incorrect
  117. Brakes: look and location of return spring?
  118. Interior: Door knob ferrules
  119. Speedo/Tach/Gauges tach.
  120. Front Axle: 2in drop spindle
  121. Engine: Use of Oil Flush Products on Stude V8--anybody have any experience?
  122. Engine: M5 Pickup
  123. Interior: 50 Commander front seat same as 50 Land cruiser seat frame? Seat covers
  124. Exhaust Avanti floor muffler heat
  125. Interior: 57 GH Instrument Panel Fiberglass Paint Color
  126. Engine: Tuning and Vacuum Advance
  127. Shocks Needed KONI Shock part number for '63 Avanti
  128. Interior: Defroster/Air Switch Removal
  129. Speedo/Tach/Gauges Looking for a speedo gear part # 1539349
  130. Clutch/Torque Converter: Clutch
  131. Transmission: 60 Lark Convert mount ??
  132. Frame/Springs putting king pin back in lower control arm
  133. Other: windshield for '55 Coupe
  134. Ignition: Erratic power to coil
  135. Body: Lovely Lark Door Interchange
  136. Electrical: Turn signal lever wobble
  137. Cool/Heat: 6v fan
  138. Other: Number of wagonaires
  139. Other: Starter Remote For 6V Pos Ground
  140. Steering What power steering fluid do you use for your 55 stude?
  141. Transmission: V8 FOM, any way to check condition short of desassembling?
  142. Rear Axle: Dana 44 interchange?
  143. Body: Anybody has a back window for a 1956 sedan?
  144. Wheels A little obscure Studebaker history.
  145. Other: Numbers for model and paint
  146. Brakes: Power brakes question, 63 Lark
  147. Drive Shaft Hoping to go from 2 pc to 1 pc driveshaft in a 54 coupe.
  148. Fuel System: '62 Hawk 4barrel carburator problems
  149. Body: Wiper Blades
  150. Electrical: Weird electrical/charging issue...maybe
  151. Transmission: Transmission Fluid
  152. Body: What is it made out of?
  153. Transmission: Overdrive Interchange
  154. Electrical: 1964 Champ wiring diagram
  155. Engine: 259 motor
  156. Cool/Heat: Older cylinder head sender removal; Bourbon tube...???
  157. Electrical: Alternator eqiipped Champ P/U 8E5 1/2 ton problem
  158. Electrical: Help!! 1959 Lark Front Marker/Turn Signal housing- double socket replacement
  159. Front Axle: Suspension blasphmey
  160. Brakes: Disc Brake Conversion
  161. Electrical: Champ Missing horn wire
  162. Body: To Ziebart or Not to Ziebart: That is the Question!
  163. Transmission: '63 Avanti Conversion to TH700r4
  164. Electrical: 1950 Champion heater switch
  165. Front Axle: 50 Champion front suspension Mods
  166. Electrical: How to set presets on my radio
  167. Ignition: Autolite part number for 56J distributor
  168. Drive Shaft Correct Position Of Bearing Support
  169. Transmission: Flightomatic problems after fluid change '61 Lark 259
  170. Fuel System: Fuel Sender range only reaches 190 ohms
  171. Electrical: I know I should know this but over 52 years I have had a brain F**T
  172. Electrical: Wallfrin electronic lighting control #403
  173. Speedo/Tach/Gauges Have you ever ???? Speedo shaft modification
  174. Electrical: Alternator equipped '64 8E5 Champ p/u
  175. Steering Has anyone installed a TightSteer Adjusting Nut for Ross Steering Gear Box in an Avanti?
  176. Engine: Car will not start after tuning up
  177. Exhaust Exhaust extensions (1957 Stude. President Classic)
  178. Frame/Springs Leaf spring frame bushing removal
  179. Electrical: Generator brush life?
  180. Ignition: Cleaning spark plugs with ammonia.
  181. Cool/Heat: Water pump manifold
  182. Speedo/Tach/Gauges Champion Temp Gauge
  183. Engine: 1957 Silver Hawk - new owner questions
  184. Cool/Heat: GT Hawk A/C
  185. Rear Axle: Torque Specs for Hub Nut on Rear Axle (1954 Land Cruiser)
  186. Brakes: Brake part needed
  187. Electrical: Alternator
  188. Paint: What color rattle can for aluminum colored bolts?
  189. Frame/Springs 60 Lark frame
  190. Body: Window aftermarket seal
  191. Fuel System: Carburetor
  192. Rear Axle: rear end ratio
  193. Engine: Intake Manifold Clamps
  194. Brakes: MIstubishi Modern, Tandem Master Cylinder On A Hawk
  195. Electrical: Voltmeter needle flutters
  196. Engine: Car Stalls when coming to a stop. 1960 Lark with LHead 6
  197. Other: 51 Land Cruiser
  198. Body: Window glass install
  199. Exhaust 66 Studebaker Cruiser 283 exhaust system
  200. Brakes: 1955 C-K front brake drums and hubs
  201. Transmission: torque converter
  202. Engine: OHV 6 Manifold
  203. Cool/Heat: Anybody else think I need a new head gasket for '55 President?
  204. Interior: 57 Golden Hawk front seat frame paint color
  205. Fuel System: Weber 38/38?
  206. Speedo/Tach/Gauges Tachometer restoration
  207. Rear Axle: Rear Axle Bearing Removal
  208. Brakes: 1963 vs 1952 Champion rear brake drum....
  209. Body: "L" shaped liner vent window seal installation on '39 commander
  210. Transmission: Bearing retainer for GM pattern T10
  211. Steering Steering damper on GT Hawk.
  212. Other: Definition of FLAPS
  213. Interior: 57 GH Seat cover clips
  214. Engine: Valve guide height
  215. Transmission: Shift linkage detention spring
  216. Engine: One moe video from Pete's Garage
  217. Interior: 59 Lark window trim... What am I missing?
  218. Electrical: Flasher for LED's
  219. Body: GT Hawk Rear Quarter Window Pocket "Fuzzy" Substitute
  220. Interior: '50 Business Coupe Rear Interior
  221. Electrical: Spark Plug gap ???
  222. Clutch/Torque Converter: Clutch housing identification.
  223. Body: 63 door latch problem
  224. Fuel System: new to me car quit
  225. Shocks Koni Shocks may be available
  226. Engine: Crankcase Ventilation???
  227. Front Axle: Avanti engine mount location
  228. Electrical: Shift indicator wire routing???
  229. Electrical: 1965 commander wiper motor
  230. Paint: green mist polly paint for 63 hawk
  231. Electrical: Turn Signal inop.
  232. Engine: Oil filter hook-up
  233. Wheels 68 MPH vibration
  234. Fuel System: Avanti Fuel Pump
  235. Interior: Seat Belts
  236. Fuel System: Upside Down Fuel Pump
  237. Steering Best place for suspension parts?
  238. Body: Door post decal
  239. Speedo/Tach/Gauges 1953 2R6 Gas gage ???
  240. Fuel System: R2 fuel pump replacement or?
  241. Body: Wiper arms
  242. Steering Electric power steering (EPAS)
  243. Steering Power Steering Pump
  244. Transmission: T86
  245. Engine: Oil Flush
  246. Cool/Heat: Heat control valve
  247. Brakes: Brake Lock Up
  248. Body: Installing Door glass?
  249. Clutch/Torque Converter: Clutch plate wear, When to replace)
  250. Other: Vibration at Highway Speed
