View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Radio, 1950 Champion
  2. gas sender test
  3. vacuum brakes? drum brakes?? 59 lark VI
  4. 63 hawk front suspension
  5. Four barrel carb change...
  6. suspension setup
  7. Spring swap?
  8. Banjo bolt headache
  9. horn ring wiring
  10. Avanti power steering + 40 years = kaboom!
  11. Champion header options?
  12. How to find original color of your car?
  13. oil pump gear
  14. engine color
  15. avanti oil filter
  16. Windlace routes, 52 hardtop
  17. valley covers
  18. Dual exhaust.
  19. Distributor oil leak Avanti R1 engine
  20. 259 auto to std trans question
  21. anyone have a R2 289 torque curve?
  22. A Bad Studebaker Night
  23. Late pan &dipstick on early FOM. Yes/No?
  24. New Avanti independent rear suspension
  25. Glass Installation
  26. A NEWBY QUESTION--57 HAWK
  27. 64 cruiser engine color
  28. engine compartment decals
  29. T-86E-1A transmission
  30. Pulling the engine - a question
  31. !964 Avanti R1 engine back pressure
  32. 6v headlights
  33. Quick Question RE: 6V
  34. Move over Kroil/PB Blaster, here comes Ballistol
  35. help needed '37 vent window......
  36. Does a Saginaw GM trans mate...
  37. whats my stude worth
  38. 56 wagon door vs 2 dr seadan door
  39. Using Chrysler rear drums for Stude front drums?
  40. 1st gear start in 57 FOM. Spring change-it works!
  41. Shocks 47 commander
  42. rear brake drums
  43. Speedometer "float"
  44. 55 Speedster Heater Blower Motor
  45. heater motor circuit -a little stumped
  46. power steering box rebuild
  47. 55 speedster color specs
  48. Cruiser no start - end of story
  49. '37 CE vent window problem SOLVED!
  50. Trying to I.D my 259
  51. Avanti II Ignition Conversion
  52. Bent Dipstick
  53. 1950 champion water pump
  54. 1950 Champion tires
  55. Whattheheckisthis?
  56. edelbrock carb
  57. 62 Hawk Reclining seats won't stay up
  58. '37 Studebaker Power Window upgrade?
  59. Custom Wheels for a 47 Champ
  60. 57 Golden Hawk...
  61. Fiberglass hood insulation
  62. copper gasket
  63. Is there a trick way to do it
  64. Clock
  65. Need to replace rear pinion grease seal
  66. 1950 Champion- no power
  67. I have a weird rear end...
  68. Lark frame- 2dr. & 4dr. the same?
  69. Will any Chevy drums work on 53 Studebaker front?
  70. Oil Breather Chrome Cap
  71. 1954 232 engine start up (HELP)
  72. Rear main seal and bearings
  73. differences 259 & 289
  74. 78 Avanti II Front End Lowering
  75. 1937 stude, electrical bulk head connector
  76. hawk front suspension
  77. Captain! We have a wee CS flange problem...
  78. hawk carb
  79. Avanti Dash Cover
  80. Lark Saginaw steering box modifications
  81. 1953 Spring Specials
  82. Rear Axle Seals, etc. on '54 Champion
  83. Engine Swap Question.
  84. 4E rear end swap
  85. Great rear end chart
  86. 55 Commander Original Engine?
  87. Power steering issue - Avanti
  88. hp limit for '51 automatic tranny
  89. I have purchased a new bird - 56 Power Hawk
  90. water manifolds question
  91. power brakes conversion
  92. 27 to 44
  93. Gas Pedal hook-up
  94. Avanti Steering Column Replacement Info?
  95. Chevybaker V8 exhaust manifolds
  96. 58 GOLDEN HAWK VALVE COVERS
  97. Not all tires are created equal
  98. Engine pull and rebuild.
  99. Pedal Stops and Heater Motor - 53 R5
  100. 1950 Champion L/Frt. brake drum
  101. 47 commander carb
  102. Heater wiring
  103. '56Power Hawk defrost motor
  104. Front Suspension (Again)
  105. timing cover conversion
  106. Opinions wanted
  107. my next needle in the hay stack search????
  108. Seat Question for C Cabs
  109. Getting ready to pull engine - UPDATE: it's out!
  110. Project A: best anti-RF ignition wiring TYPE
  111. Leaking coolant from 289 Convertible
  112. 63 Gt Carburator-Carter AFB 2312 OK?
  113. 1951 PICKUP HELP
  114. 289 carb.
  115. Speedster Engine
  116. Avanti Chrome engine parts
  117. Advice on Replacing 289 Crankshaft
  118. Trans Fluid?
  119. 1950 Land Cruiser Exhaust Donut
  120. Forums for Dummies
  121. NAPA gaskets
  122. Sliding Truck Seat - any advantage?
  123. Terminal block question
  124. Avanti steering box in a Lark
  125. 59 Lark steering problem
  126. Painting?....
  127. Speedometer cable on 1954
  128. 1955 224" V8 pistons needed
  129. Gas tank coating removal
  130. 289 Engines and Cranks
  131. Chev engine mounts
  132. exhaust ports
  133. 54 starliner hardtop -WIPER MOTOR
  134. installing a supercharger
  135. Steering column swap ?
  136. Crankcase Pressure
  137. Headliner cement
  138. S-10 rear end in 52 Studebaker
  139. Too many springs.
  140. tire diameter
  141. How do you get spring bushings out?
  142. Pictures of new Avanti frame/ front crossmember
  143. Different exhaust placement for an Avanti?
  144. 53 c body coupe
  145. Dana gears for sale
  146. Window interchange
  147. avanti pitman vs starter
  148. Hydrovac Brake System
  149. How do I get my thermostat out?
  150. Wanted lark steering box and bellcrank
  151. I think the old gril liked the V8...
  152. Wheel Cylinder 1557668 inter-change.
  153. Newbie Intro
  154. v8 heads
  155. metal manifold gaskets vs. composition
  156. hawk suspension 2
  157. 1950 champion thermostat
  158. Rear 1/4 windows on a '55 hardtop
  159. loss of water in engine
  160. Fuel gage sending unit gasket
  161. 65 Studebaker drivetrain
  162. Carburetor Help!
  163. Transmission
  164. 53 Starliner radiator replacement?
  165. R2 fuel and timing questions
  166. temperature sensor,
  167. Bellhousing alignment questions
  168. Identification help
  169. 1964 Studebaker Gran-Turismo Hawk Tech Help
  170. Firing order
  171. M-5 Truck
  172. Odd VIN number...
  173. Speedster Gages and Panel
  174. 1951 Business Coupe Regal? Deluxe? Custom?
  175. Overdrive on Post-1964 Studebakers
  176. more paint questions....
  177. Towing a lark
  178. engine colors
  179. Stock thermostat for '51 V8?
  180. updating brakes
  181. Parts Needed
  182. Super charger question
  183. What happens when the dowels are missing
  184. Bendix power steering
  185. dg 200 transmission?
  186. McKinnon 194 Six Cylinder Performance
  187. Carburetor Troubleshooting Chart
  188. Drum Brake ??
  189. Avanti - Steering Too Loose
  190. CFM Requirement for 289
  191. Manuals on CD
  192. body parts
  193. Would a rebuilt engine with less than 2k seize?
  194. Where to get my engine rebuilt
  195. Parts needed 59 Lark
  196. HURST 4 SPEED SHIFTER
  197. 41 Commander
  198. need some help
  199. need parts
  200. Front shocks-64 Lark Types. Who makes 'em?
  201. Lark serial numbers
  202. Overdrive Solenoid
  203. U JOINT ?? FOR S10 REAREND SWAP
  204. 289 crankshaft & pulley/damper questions
  205. Master Cylinder for 64 Daytona
  206. 1952 V-8 distributor install
  207. Another 6-Volt Charging Question
  208. Paint for a frame
  209. Installing control arm bushings
  210. what is the replacement for 670/15 tires ?????
  211. Modern Pistons & Rods
  212. R END SWAP SUCCESS & THANKS
  213. Stud remover
  214. frame swap
  215. Tranmission Cooling
  216. bleeding brakes
  217. Delrin bushings?
  218. P&D Ignition Parts Cross Reference Needed
  219. Hawk Door replacement
  220. heater motor
  221. Hawk defroster hose
  222. Hydrovac parts?
  223. Early model vent window replacement
  224. HEELLPPPP!
  225. FOM rebuild / update
  226. Engine Swap Have 6 want to chang to bigger 6
  227. Weatherseal help URGENT
  228. 54 Hardtop brake upgrade
  229. Hawk wiper switch
  230. 54 Starliner wheels/tires
  231. still working on the 37
  232. Main Caps Not Numbered
  233. Starter interchange?
  234. Need 19.5 Rims & Hubcaps for 59 4E11
  235. Power Steering question
  236. REACH ROD HITTING HEADERS HELP!!
  237. Shock absorbers- who makes em?
  238. Wanted: Front Seat belts
  239. Garage finally done..now 4 the Lark
  240. 6 cylinder ignition-should I shield from weather?
  241. Crank end play shims
  242. It's ALIIIIIIVE!
  243. Had an accident with the jack...
  244. Hub puller 24 special 6
  245. 289 overhaul
  246. Funny symbol stamped on engine
  247. Valve cover driver side 55 state sedan
  248. head numbers
  249. old gas tanks
  250. POR Dealer?
