View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 [108] 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Clutch/Torque Converter: 66 commander pressure plate step?
  2. Body: 1928 Dictator window shade information
  3. Transmission: Identifying an Avanti automatic transmission?
  4. Electrical: Redmond Wiper motor; wiring diagram...
  5. Brakes: Sky Hawk Rear Wheel Cylinder?
  6. Transmission: Speedo gear ratio for 700r with 3.31 rear end
  7. Electrical: no nothing
  8. Body: 1932 Studebaker Commander eight - Locking Outside Door Handles
  9. Electrical: Microfarads of the Condenser?
  10. Wheels 1959 Lark center hubcaps
  11. Other: glass for 56 Golden Hawk
  12. Electrical: Gas gauge pegged
  13. Electrical: headlight wiring protection
  14. Electrical: For those thinking 6V is a problem but don't want the hassle of switching to 12V
  15. Engine: Hawk Heating Concerns
  16. Brakes: 2R16A Master Cylinder
  17. Frame/Springs New Info on CC655 Springs...
  18. Engine: Parts cleaning at Pete's Garage
  19. Engine: 232 vs 289 engine and auto transmission weight
  20. Engine: '63 Cruiser Drivetrain swap into a '60 Lark Wagon....
  21. Body: Hood Alignment post number eleventy-seven
  22. Cool/Heat: Radiator Interchange '53 C/K
  23. Brakes: New Dual Hydrovac
  24. Cool/Heat: After market Hawk dash
  25. Steering Steering gear repair of replacement on E3 11
  26. Engine: OHV 6, myth?
  27. Frame/Springs Upgrade front suspension?
  28. Engine: Accelerator Pump Question
  29. Body: Replacing u-channel in Champ Pickup
  30. Brakes: Brake master cylinder kit
  31. Brakes: Bit Of A Parking Brake Mystery
  32. Body: 54 Coupe rocker panels - am I missing an inner sill panel?
  33. Brakes: 39 commander brake question
  34. Transmission: Service letter 868 Automatic Drive
  35. Engine: Weber 32/36 on OHV 6?
  36. Body: Painting '55 Vent Screens
  37. Brakes: Braking rod
  38. Body: Exploding Hawk Hood Latches
  39. Electrical: Interchangeability of 170 Champion Autolite distributors?
  40. Wheels Wheel upgrade issues
  41. Ignition: Distributor
  42. Frame/Springs How to identify frame year and model under a 54 coupe?
  43. Steering Power steering leaks
  44. Fuel System: Vintage Premium Gasoline - Coming To A Pump Near You?
  45. Ignition: Chrysler/Prestolite Ignition
  46. Electrical: Avanti Courtesy/Dome Lights
  47. Electrical: 57 Golden Hawk Rear Harness Routing
  48. Ignition: delco distributor for a 56 golden hawk
  49. Shocks 57 Commander shocks
  50. Brakes: Hawk brakes master cylinder
  51. Wheels Bob Palma, Studebaker Co-Operator Query
  52. Engine: '35 Commander compression test numbers
  53. Interior: LOOKING FOR '55-'61 Hawk dashboard for my '54 coupe
  54. Transmission: 200-4R Brake Light Switch Function
  55. Interior: Interior Compatibilit
  56. Clutch/Torque Converter: 200-4R Brake Switch
  57. Fuel System: Ethanol free gasoline storage
  58. Clutch/Torque Converter: Flywheel ring gear tooth count.
  59. Engine: Machining the block
  60. Body: s10 or full size frame?
  61. Cool/Heat: 1932 Studebaker Commander Eight Model 71 - Radiator
  62. Body: '39 Coupe Express wing window divison bar problem
  63. Engine: Trans -adapt carbertor flange ( 1955 ,259 , 4 barrel
  64. Engine: A modest proposal - Build how you drive.
  65. Clutch/Torque Converter: New Polyurethane Elastomer Boot
  66. Transmission: 60 Hawk Auto Trans
  67. Transmission: 62 Flight-O-Matic Type A or Type F?
  68. Front Axle: Front suspension rubber.
  69. Steering Dropped Spindles
  70. Body: hood springs
  71. Engine: R2 cylinder head
  72. Steering Quick Steering Arms on 53 - need shorter tie rods?
  73. Interior: upholstery
  74. Transmission: 56 or 57 Flightomatic to adapt to 55 V8
  75. Engine: Cylinder heads : 101
  76. Other: Replacement floor pan quality?
  77. Other: 6 Volt Radio Vibrator
  78. Body: Elusive manual window regulator
  79. Engine: Engine info.
  80. Engine: Dual Quads on Studebaker V 8
  81. Body: Any ideas on what these six fasteners are used for? 1955 President State Sedan
  82. Fuel System: fuel gauge/sender unit issues
  83. Electrical: Converting '54 coupe with '56 dash to 12v -- what fuel sender to use?
  84. Electrical: Radio Hook-Up
  85. Engine: Engine overheat
  86. Steering Adjuster set screws
  87. Speedo/Tach/Gauges Wood grain treatment
  88. Body: Help: Door handle '57 Golden Hawk
  89. Brakes: dual master cylinder for 1950 Champion
  90. Frame/Springs leaf spring bushings
  91. Body: 1962 GT Hawk trunk lid overlay ..
  92. Body: Grill Finish 62 GT
  93. Body: 50 Champion Starlight front grill trim
  94. Electrical: I have been grounded
  95. Engine: Olds Valve Covers
  96. Paint: 1953 starliner paint code.
  97. Shocks 65 cruiser front shock mount
  98. Other: Manuals
  99. Engine: Help with part numbers.
  100. Brakes: 11" front brakes
  101. Rear Axle: '39 commander rear axle seal
  102. Other: Question for Hylomar M Users
  103. Interior: Anyone have any advice???
  104. Exhaust Muffler preference
  105. Speedo/Tach/Gauges Cruise control suggestions?
  106. Body: K body vent window installation tip
  107. Body: 50 Champion Doors Handles
  108. Transmission: TKO 500/600 into Avanti console problem
  109. Body: 1950 Champion Starlight Trunk Tail Panel
  110. Engine: hard starting when warm
  111. Engine: Shouldn't need anything more than a light cleanup and paint before bolting on and driving away.
  112. Transmission: flightomatic mounts
  113. Wheels What Tres?
  114. Rear Axle: Which Rear axle was stock in a 50 Champion Starlight
  115. Interior: 1957 Wagon Cargo Material
  116. Engine: 1 Set (2) 1949 1950-58 Oldsmobile 303 324 371 RUBBER Valve Cover Gaskets
  117. Engine: western canada machinist required
  118. Electrical: Starter Tip
  119. Front Axle: Straight Axle
  120. Electrical: factory directional light problems
  121. Transmission: DG150 in Commander
  122. Body: 63 Lark Trunk Springs
  123. Body: K body quarter window run felt repair pictures
  124. Brakes: 1962 GT Hawk rear parking brake cable routing
  125. Body: 1960 HAWK Missing Trim / Adding Seatbelts
  126. Interior: 1950 Champion Loose Sun Visor
  127. Exhaust Champ Muffler
  128. Electrical: '61 Lark Turn Signal Switch
  129. Transmission: flightmatic conversion
  130. Electrical: Extra loud flasher
  131. Body: 1961 Lark Radio Antenna
  132. Fuel System: Air cleaner for a 4bbl carburetor - 1961 Lark
  133. Interior: Door Panel Interchange
  134. Speedo/Tach/Gauges Do I need to bleed the oil pressure gage pipe?
  135. Fuel System: Filling tank without spilling
  136. Steering Custom Stude suspension
  137. Body: Window felt-'57 Packard
  138. Steering 50 Champion front end rebuild
  139. Body: 1954 to 1959 Lower Tailgate Assembly
  140. Body: Hood Reinforcement
  141. Steering 50 Champion Idler Arm (526327)
  142. Shocks Replace Houdaille shocks
  143. Transmission: What model is it?
  144. Body: Hawk side grills?
  145. Electrical: Temp sender
  146. Other: what can you tell me about my new Avanti
  147. Engine: Bad crank
  148. Engine: Cylinder head pics?
  149. Engine: Leaky fuel pump = gas in the oil?
  150. Interior: Would rear seats from a 1980 Avanti fit in my 1963 Avanti?
  151. Electrical: small motors
  152. Brakes: 1949 2R5 Brake Questions
  153. Engine: Historic question...
  154. Body: Parts,parts,parts....
  155. Brakes: Front Brake Line Junction Block
  156. Interior: 1960 Hawk - Adding Seatbelts
  157. Frame/Springs Re-arching springs
  158. Front Axle: need a part number for a grease seal
  159. Clutch/Torque Converter: Pressure plate adjustment
  160. Body: 51 and 52 fenders
  161. Brakes: Help removing studs from hub (rear brakes)
  162. Other: door post vin tag
  163. Cool/Heat: Heater hose routing for '62 GT Hawk
  164. Engine: Digram with crank flange to block measurements
  165. Engine: Rear Main Seal Woes
  166. Shocks Houdaille shock absorber fluid
  167. Electrical: Generator to Alternator Changeover
  168. Frame/Springs Truck spring interchange.
  169. Brakes: Remote brake reservoir
  170. Brakes: Primary and secondary brake shoes
  171. Body: Removing Vinyl....?
  172. Engine: R1 heads
  173. Paint: I need your help again!! The white on 1955 grill inserts
  174. Engine: R-2 Crankshaft damper
  175. Transmission: Results of not dial indicating the bell housing
  176. Engine: Backfiring: electrical or fuel ??? 1953 Big 6 w/ OD, (1/2 ton truck w/ 6 ply tires)
  177. Engine: Next video up on youtube
  178. Body: Avanti vent window rubber
  179. Brakes: Correct Swaging Procedure?
  180. Transmission: Jaguar Automatic Transmissions
  181. Rear Axle: Rear axel seals
  182. Engine: Test Result Interpatation Help?
  183. Engine: Parts to build an R2?
  184. Engine: rod
  185. Body: gt hawk body removal
  186. Electrical: Dim Dash LightsT
  187. Steering What pump to use with engine conversion
  188. Engine: Head and manifold gasket
  189. Engine: Numbers
  190. Engine: R2 RPMs while choked?
  191. Body: C cab hood hinge
  192. Body: Bear claw latches in a C Cab?
  193. Electrical: 2R5 Parking Lights
  194. Transmission: Chevrolet overdrive to studebaker engine
  195. Engine: 1964 engine serial #
  196. Rear Axle: Dana 44 Twin Traction Questions
  197. Body: GT Hawk sport top
  198. Interior: Identify some parts from a '55 Speedster
  199. Fuel System: electric fuel pump for 259 with Edelbrock 500 cfm
  200. Electrical: 1940 president headlight switch
  201. Fuel System: M5 gastank removal
  202. Fuel System: Offenhauser dual carb setup for the flathead six
  203. Interior: Interior upgrades.
  204. Body: 50 Champion Undercoating inside cabin?
  205. Interior: 50 Champion Nail strips
  206. Engine: Need some starter motor help
  207. Transmission: rear transmission yoke...help!
  208. Transmission: how to check overdrive solenoid?
  209. Electrical: Tac sender
  210. Frame/Springs Coil springs 1966. Need help identifying
  211. Body: Gt body& frame
  212. Steering 57 Provincial Wagon PS hoses-Restriction?
  213. Electrical: Amp meter wild swings
  214. Cool/Heat: Installing radiator support frame
  215. Interior: Dying a 292351X6 Armrest Pad
  216. Speedo/Tach/Gauges Ammeter With 12SI Alternator
  217. Engine: Engine painting
  218. Fuel System: Gas will not come out of the gas tank
  219. Engine: V8 can't find ID.
  220. Body: Need help with damaged 41-42-46 Champion hood hinges and hood alignment.
  221. Cool/Heat: '62 GT Hawk, under fender heater blower.
  222. Engine: Supercharger Boost Gauge Install?
  223. Electrical: 62 hawk dashlights
  224. Ignition: Studebaker Lark door key blanks
  225. Steering retro fitting new steering rack 65 cruiser
  226. Electrical: Head Light Spring ?
  227. Body: Best way to deal with rust below rear edge of 2 dr 66 back window
  228. Electrical: 57 Golden Hawk Firewall Picture
  229. Fuel System: Fuel Pump for a 63 259 same as 1956 289?
  230. Body: 50 Champion trunk handle disassembly
  231. Brakes: 61 Champ Brakes
  232. Steering power steering
  233. Body: power steering
  234. Fuel System: Idle control when choked?
  235. Engine: What is the easiest way to add cruise control to a 1964 Daytona with 259 bbl. carb. and overdrive?
  236. Cool/Heat: Adding AC To GT
  237. Engine: Head / Intake / Block Angles
  238. Electrical: Putting a one wire alternator in my 62gt hawk
  239. Engine: Head Gasket Leak
  240. Transmission: O.D. Transmission Oil
  241. Steering Power Steering Unit Identification
  242. Ignition: Distributor Advance Question
  243. Steering Want cheap power steering?
  244. Engine: 1963 259 rebuilding, should I buy a 289 crank for it?
  245. Engine: engine sputters at speed
  246. Engine: Studebaker V8 Engine Cradles
  247. Brakes: New discs installed, but right front skids
  248. Body: Spare tire trunk lid
  249. Electrical: electric power steering
  250. Body: Avanti mechanics--how strong are the aprons near the latch area??
