View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 [105] 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120
  1. Body: Lark Bumpers
  2. Brakes: Bleed sequence
  3. Ignition: Ardunallard
  4. Fuel System: R2 Fuel Setup for '57 Supercharged Golden Hawk; does this plumbing sound correct?
  5. Brakes: What is correct brake line diameter for 57 Golden Hawk???
  6. Cool/Heat: A/C Convertion
  7. Clutch/Torque Converter: Need help identifying part
  8. Cool/Heat: Fan Shroud
  9. Electrical: 47 Ignition switch wiring
  10. Clutch/Torque Converter: '61 Lark VIII wagon clutch operating shaft question
  11. Steering Ross Gear Box
  12. Rear Axle: Tag on housing
  13. Engine: Automatic choke on 1951 Commander
  14. Electrical: Now gas gauge troubles.
  15. Body: 57 'C' body weatherstripping orientation
  16. Steering '64 Avanti R2 power steering is much easier in one direction
  17. Fuel System: what are the pick-up tube for gas tank supply specs or requirements (Hawk)?
  18. Fuel System: vapor lock?
  19. Engine: car acting like its out of gas
  20. Body: Well Nuts
  21. Wheels Proper tire size for 1963 Cruiser.
  22. Body: 1964 Grille Refinish
  23. Body: Deck Lid Adjustments
  24. Brakes: Soft Brakes
  25. Ignition: electronic ignition- '55 V8
  26. Interior: Stripped mounts for sun visor (1966)
  27. Brakes: Front Brake Drum Grooves
  28. Engine: spark plug selection experts?
  29. Interior: 1957 Packard Dashboard Core Wanted
  30. Drive Shaft Sky Hawk U-Joint Series Question
  31. Electrical: Engaging Overdrive Causes Discharge
  32. Steering Modern steering gear
  33. Other: 1929 Studebaker President Differential Parts Diagram
  34. Engine: super charger
  35. Body: C/k hinge repair
  36. Shocks Question about Air Shocks
  37. Brakes: 56 Golden Hawk Power Brake
  38. Engine: Engine cutting out under acceleration
  39. Body: Snapped Bolt Repair Ideas Needed
  40. Electrical: Help from radio restoration experts
  41. Exhaust Need flange gasket part number for NAPA, etc.
  42. Brakes: master cylinder
  43. Transmission: Drug Thru The Sh** And The Rope Broke!
  44. Fuel System: 1926 EP Big Six carb parts needed
  45. Fuel System: My fuel pump makes a ticking noise
  46. Body: Where To Undercoat Fender/Firewall?
  47. Electrical: '50 Champion doesn't turn over when hot
  48. Front Axle: 63 Cruiser need front suspension work.
  49. Cool/Heat: A/C Braclet.
  50. Cool/Heat: Upper radiator hose for 63 Cruiser 289 V8 w a/c.
  51. Body: Trunk Antenna GT Hawk - Reinforcement plate?
  52. Body: Weather Stripping Question
  53. Engine: Need an opinion.
  54. Transmission: Transmission Mounting Tab Thickness?
  55. Body: Suspected Rust Under Vinyl Roof
  56. Transmission: Avanti - Downshifts to second at 50 mph and will not shift back to third
  57. Other: The Impossible part to find
  58. Speedo/Tach/Gauges 1964 Commander speedometer cable
  59. Rear Axle: Rear axle torque and grease
  60. Transmission: Differences (if any) between '56 Golden Hawk T85 manual and '57 or '58 Golden Hawk T85?
  61. Brakes: Grinding from rear brakes 62 Hawk
  62. Electrical: Champion light switch question
  63. Engine: Another idea
  64. Electrical: Headlights on 1952 2R5 Pickup
  65. Body: Emblem removal/reinstall
  66. Brakes: Wilwood master for Avanti
  67. Body: Removing Rear Side Window?
  68. Fuel System: Anyone use the electric fuel pump from 5th Ave garage
  69. Cool/Heat: Almost over-heating
  70. Brakes: '59 Lark Brakes
  71. Brakes: Brakes for 2/R11
  72. Other: '53/54 C/K horn brackets and mounting location? Pictures needed
  73. Body: Removing a Vinyl Top
  74. Steering Manual steering box lube
  75. Cool/Heat: Bad Frost plug hole
  76. Rear Axle: Traction Bar Questions
  77. Body: Need help finding 1939-46 Champion wiper part numbers
  78. Wheels Auto Transport: Wooden Wheels: Require special handling?
  79. Body: Removing a c/k headliner?
  80. Engine: Motor/Transmission mount holes
  81. Frame/Springs C/K Front Seat Mount
  82. Engine: 1940 studebaker
  83. Engine: Rear Oil passage leak
  84. Interior: 64 Hawk Headliner Retainer strips
  85. Other: Torque Box Replacement
  86. Engine: Fairborn Adapter Starter?
  87. Other: Air Compressor
  88. Engine: Exhaust Manifold Painting
  89. Other: 1946 champion
  90. Fuel System: Vapor locking?
  91. Engine: Stuck engine
  92. Cool/Heat: Expansion Valve
  93. Brakes: 2R11 Brakes
  94. Brakes: Disc Brakes on A Champ?
  95. Fuel System: intake manifold
  96. Electrical: Defroster Switch Resistor?
  97. Paint: Cherokee Red matches?
  98. Electrical: LED Signal Lights
  99. Brakes: Bore size of Studebaker Avanti Master Cylinder
  100. Engine: valve cover
  101. Engine: Off with his head!
  102. Exhaust '37 straight eight manifold heat riser valve
  103. Interior: Modern radio to fit 57 hawk
  104. Brakes: Avanti discs on a '59 Lark
  105. Rear Axle: Twin Traction Ping or Clang
  106. Interior: '64 Glove box?
  107. Other: Got my radio back for the '53
  108. Paint: Interior trim paint: gloss, matte or flat?
  109. Body: M5 and M15 bumper bracket interchangeability
  110. Shocks Knee Action Shocks Rebuild
  111. Paint: Paint Specs -- chips and/or formulas
  112. Engine: Rebuilding a 1922 carberator.
  113. Engine: Rebuilding 259 with upgrades
  114. Steering ID these tie rod ends?
  115. Frame/Springs 1950 commander 4 door big 6 auto
  116. Body: front fenders
  117. Electrical: W.W. Wiring
  118. Other: 32 St. Regis Possibly?
  119. Other: Mirror help
  120. Other: Mystery bolts falling from my car! Help!
  121. Brakes: Harley brake light switches
  122. Cool/Heat: Stuck temp sender
  123. Engine: Rocker cover gasket
  124. Ignition: Proper timing..
  125. Electrical: 1925 Studebaker ER (standard) Engine Electrical Problem
  126. Other: Information/instrumentation: What would you like to have?
  127. Engine: 1957 Transtar--been off the road for 25 plus years
  128. Electrical: Back Up Lights 62 GT
  129. Electrical: Avanti Gauges
  130. Electrical: Toggles on the inside roof.
  131. Electrical: 1956 Parking Light Harness...
  132. Fuel System: Gas Tank
  133. Engine: A/F ratio
  134. Transmission: Automatic Transmission??
  135. Electrical: No Juice to the Starter?
  136. Speedo/Tach/Gauges No Tach after engine swap?
  137. Body: '53-'64 C/K deck lid hinge repair service
  138. Interior: insulation/weather seal(s) between door and interior panel
  139. Engine: 289 pistons
  140. Engine: Need correct Diameter of the Supercharger Pulley
  141. Steering power steering fluid
  142. Rear Axle: ring gear and pinion
  143. Interior: Front seat back is loose.
  144. Engine: questions about 283 chevrolet engnes in studebakers
  145. Body: Windshield trim - mystery screws - 1961 Lark Regal Station Wagon
  146. Body: "53 Boot lid hinges
  147. Other: speedometer and/or cable
  148. Engine: oil all over front of engine Avanti R2
  149. Body: Hood weatherstrip
  150. Transmission: Photo Help - '49 2R10 Overdrive
  151. Fuel System: Flathead dual carbs....
  152. Engine: Spitting Water out the Exhaust/GT R2 Hawk
  153. Wheels M-5 Tire Size
  154. Other: 1959 lark what fluids to use? Oil, trans, rear diff......
  155. Wheels 16" or 17" wheels?
  156. Body: 2R10 Headlight buckets
  157. Interior: 1957 GH Antennas
  158. Electrical: Starter Motors -all the same mounting patterns?
  159. Electrical: 1957 Transtar--battery?
  160. Transmission: Burning Up My 200-4R
  161. Electrical: Burning Out a Pertronix Unit
  162. Paint: Avanti Paint Removal Suggestion.
  163. Fuel System: New fuel line for '54 Land Cruiser
  164. Electrical: 64 Avanti PW
  165. Electrical: Fuel tank sending unit
  166. Electrical: 1950 Champion Radio: question on antenna
  167. Body: 53 Hood Safety Catch Search
  168. Electrical: How to polarize a generator?
  169. Frame/Springs I need the front engine mounts that are riveted to the frame for a '53 '54 C/K
  170. Engine: Rebuild Fire up Success
  171. Brakes: Rear Backing Plate- E-brake 'support' bolts all broke off; replacements?? (welded in)
  172. Engine: Correct air cleaner
  173. Frame/Springs leaf spring shackles for a hawk
  174. Electrical: gas gage on full
  175. Transmission: Rebuilding a 61 Lark Flightomatic transmission.
  176. Electrical: 6 volt power windows...
  177. Engine: Engine numbers.
  178. Cool/Heat: stuck thermostat engine 170
  179. Fuel System: Easy Question
  180. Other: First things first
  181. Transmission: Flight O Matic: same for V8 & 6?
  182. Speedo/Tach/Gauges What are the chances
  183. Engine: Starting 1950 Champion for first time in 20 years
  184. Ignition: Prestolite vacuum advance???
  185. Brakes: Wheel Cylinder
  186. Cool/Heat: Need some cooling system help !!
  187. Engine: engine tilt front to rear , 1949 2R16A
  188. Electrical: It's Official: I'm too Old!
  189. Steering 6 cylinder power steering photos
  190. Paint: Refurbishing hubcaps
  191. Rear Axle: Rear axle and nut size 1955 Commander
  192. Transmission: Studebakers starting out in second
  193. Transmission: 51 linkage from throttle to A/T
  194. Fuel System: Gas gauge or sending unit?
  195. Body: OEM Style Tailgate for 49 2R10
  196. Cool/Heat: Engine block core plugs.
  197. Electrical: '61 Lark V8 Generator Trouble
  198. Rear Axle: Differential Gasket and steering Gear lube
  199. Brakes: Any Particular Rebuild Order
  200. Engine: Crankshaft Question
  201. Brakes: Need Rear wheel cylinders 1955 E12
  202. Electrical: 12 volt limiter for 6 volt gauges.
  203. Body: Car Cover: 62 GT Hawk
  204. Wheels Looking to get schooled - info needed on rim swap
  205. Transmission: best transmission swap?
  206. Fuel System: Looking for brass fitting that screws into fuel pump (232 V-8)
  207. Body: Need help with body bushing locations '46 Champion
  208. Interior: Glovebox light bulb
  209. Engine: Looking for 1959 Studebaker Lark Motor Mounts
  210. Rear Axle: Driveshaft Angle for 49 Stude 3/4 Ton Truck
  211. Fuel System: Choke pull-off
  212. Cool/Heat: A/C DRIER for '64 Lark
  213. Transmission: Column shift adjustment
  214. Steering Power steering control valve
  215. Other: Wiper blades.
  216. Drive Shaft End Play for a '63 Hawk/4-spd driveshaft
  217. Cool/Heat: 1964 GT upper Radiator Hose
  218. Body: hardtop body askew, doors do not fit right
  219. Body: Jury-rigged trunk spring stretcher
  220. Brakes: Transtar Wheel Cylinders
  221. Body: Daytona Structural differences?
  222. Engine: Head bolt length?
  223. Transmission: T86 new rear seal leaking
  224. Brakes: Rear drum puller?
  225. Frame/Springs 1962 Hawk Frame Dimensions
  226. Fuel System: 53 Hardtop Gas Tank
  227. Steering Steering Gear Seal
  228. Electrical: Harness Routing for 1956 Hawk Parking Lights...
  229. Interior: headliner
  230. Steering Adding Power Steering
  231. Frame/Springs differential-to-spring blocks; broken 'centering plug', critical?
  232. Clutch/Torque Converter: Clutch problems!!
  233. Transmission: T86 rear seal leak UPDATE w/speedo pinion question????
  234. Frame/Springs Jacking up the front
  235. Body: In need of 77 Avanti Bumpers
  236. Fuel System: Bad flat spot on my 64 daytona 289 with carter afb
  237. Fuel System: Bendix Carb ID
  238. Engine: Golden Hawk not running well
  239. Electrical: courtesy lights
  240. Body: '54 passenger vent door / speedester side trim
  241. Electrical: signal lights 1949 studebaker champion convt
  242. Frame/Springs Leaf spring clips
  243. Transmission: 1951 Champion automatic transmission
  244. Other: Tires and air loss
  245. Fuel System: Fuel Sending Unit
  246. Interior: Mirror Mirror on the ......
  247. Transmission: Correct GT Hawk shift plate
  248. Front Axle: Delrin control arm bushings ?
  249. Ignition: Starter problems
  250. Electrical: R2 GT Hawk Alternator Issue
