View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 [103] 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Rear Axle: My TT diff sounds English - It is whining.....
  2. Brakes: Rear Brake Drums
  3. Engine: Flat Top 289 Pistons
  4. Body: Windshield washer for Champ
  5. Steering Stock Stude PS vs. going with an Astro gear on a 1959-66 Lark type?
  6. Transmission: Borg Warner DG-200 transmission rebuild - need advice from the pros
  7. Brakes: Parking brake adjustment (1966)
  8. Brakes: Possible way around the tapered axle rear drum removal drama.
  9. Steering power steering
  10. Electrical: Converting a '51 Land Cruiser from 6 volt - 12 volt. Bulb conversions?
  11. Electrical: bulbs that can be seen
  12. Engine: rebuild a short block
  13. Body: Quiz - what's that part?
  14. Electrical: 56 GH: corect radio?
  15. Cool/Heat: Basic radiator flushing question
  16. Transmission: Borg Warner DG-200 vs. DG-250M
  17. Engine: 1940 Commander Oil overflow drain tube......
  18. Other: Help to Decode VIN
  19. Interior: How to Make a Champ truck seat fold forward
  20. Body: '64 Cruiser stainless rocker moulding clips installation help needed
  21. Body: 59 Hawk New Side Vent Rubber Gasket Problems Installing/sealing
  22. Transmission: new shifter for T96 O/D
  23. Electrical: Instrument light switch
  24. Body: I need a picture
  25. Transmission: looks like a bargain for a 4-speed
  26. Engine: WTB Studebaker original fan belt 529374
  27. Electrical: Aftermarket Wiring Harnesses and Volt/Amp Guages
  28. Electrical: 64 gas tank sender ohms
  29. Fuel System: Wcfb 2219s
  30. Speedo/Tach/Gauges no action Speedo
  31. Other: Hose Clamps
  32. Brakes: Adding "factory" power brakes to a '55 President (Ultra Vista) 4 door
  33. Ignition: Ignition switch issue
  34. Engine: Engine Stuffing
  35. Exhaust Exhaust Manifold Gasket
  36. Brakes: Emergency brake cable
  37. Rear Axle: Jaguar IRS for Avanti
  38. Engine: engine bogged down
  39. Ignition: starter solenoid problems on an Avanti
  40. Steering Possible Substitution for Ross manual box on a '56 Power Hawk?
  41. Brakes: Brake lights come on for no reason
  42. Transmission: spring clips?
  43. Fuel System: edelbrock 1403
  44. Engine: horsepower ratings in 1955 259 engine
  45. Brakes: 62 Hawk front ebrake cable clip
  46. Body: 54 c body vent window removal
  47. Wheels Need one wheel cover 2799
  48. Body: Hood stuck closed, 50 Champion
  49. Cool/Heat: need a temp sending unit for 283 v8?
  50. Electrical: 1952 Headlight switch
  51. Brakes: Hill Holder bleed
  52. Transmission: Sky Hawk T86 Shifter Forks
  53. Transmission: Bell Housing or Transmission?
  54. Ignition: Distributor Tag Numbers
  55. Steering Driving with power steering fluid leak
  56. Electrical: S.I goes the extra mile
  57. Ignition: spark plug wires
  58. Other: 17A Commander?
  59. Interior: Headliner Install
  60. Transmission: Hurst Shifter Install (Ford Pick-UP)
  61. Body: Some New Pictures
  62. Interior: bucket seats
  63. Steering Steering Woes
  64. Fuel System: Airtex WCFB kit
  65. Engine: Timing gear whine
  66. Ignition: Timing question
  67. Electrical: Honda alternator/ electronic regulator
  68. Electrical: White stuff in the battery tray
  69. Body: Bellows Thingie
  70. Rear Axle: What diff do l have?
  71. Body: 64-66 rust along edge of roof line?
  72. Transmission: Auto Dip Stick Leakage Question
  73. Electrical: Prestolite 4108
  74. Engine: Low Cost Source for Oil Filters.
  75. Electrical: Ignition switch lamp
  76. Steering power steering 58 Hawk
  77. Transmission: Shiftless in Wisconsin
  78. Body: Bent flange on the 39 grill.
  79. Engine: Exhaust Manifold Bolts On 55 C-Body V-8
  80. Cool/Heat: Water Pump
  81. Electrical: What size (amps) of alternator would be best for my car? (update)
  82. Transmission: Flightomatic clutch cylinder
  83. Engine: Carburetor Automatic Choke Heat Tube
  84. Steering Steering wheel splines, cracks, shifter mods.
  85. Transmission: Fluid
  86. Electrical: 1961 Hawk Wiring Diagram missing?
  87. Engine: to un stick a engine ????
  88. Electrical: 55 ,2 door c body , where do I find the postive ground? eletrical port socket
  89. Electrical: Tips for doing under dash work in '61 Lark?
  90. Body: Mount hub for '55 Wire cover
  91. Steering Turn signal won't cancel
  92. Fuel System: Ugh.... Tank crud....
  93. Interior: 1953 Commander dash color question
  94. Engine: Flow restricter bypass filter system
  95. Electrical: Fried Module (hold the mayonnaise)
  96. Engine: Engine numbers
  97. Wheels 1950 Land Cruiser wheel
  98. Other: Regarding 4 post Made in China lift:
  99. Rear Axle: Dana 44
  100. Engine: Oil Pressure Relief Spring
  101. Brakes: 1950 Champion Brakes Locking up
  102. Wheels Hubcaps
  103. Transmission: Four speed overdrive question
  104. Front Axle: Front springs of 54 Champion - any good?
  105. Paint: Paint removal suggestions?
  106. Speedo/Tach/Gauges Wiring Stewart Warner Ammeter, Fuel, Temperature, and Oil Pressure Gauges
  107. Body: Where do these go?
  108. Fuel System: Brain pick .... need an R3 Purist
  109. Frame/Springs gt hawk frame
  110. Steering '55 Champion standard Saginaw steering gear seal
  111. Electrical: opinions/experiences on AGM vs flooded cell batteries?
  112. Fuel System: Cough, cough, hesitation
  113. Fuel System: What's the going price...
  114. Speedo/Tach/Gauges Speedo Drive
  115. Brakes: Yet another ebrake question 62 GT
  116. Engine: hot rod Studebaker Champion manifold only $41
  117. Steering Late Champ steering linkage
  118. Speedo/Tach/Gauges odometer doesn't work.
  119. Ignition: prestolite distriutor
  120. Engine: R2 Head casting numbers
  121. Transmission: 26 Tooth Speedometer Pinion Gear 531202
  122. Engine: Timing marks !!
  123. Transmission: Speedometer pinion gear
  124. Engine: Is my engine shot?
  125. Engine: Resistor or No Resistor Spark Plug Wires for 259V8?????????
  126. Transmission: transmission identification
  127. Brakes: 63 R2 disc brake Hawk front brakes locking
  128. Rear Axle: Top Cruise Speeds Question
  129. Fuel System: Holley Carb - Running too rich
  130. Body: 1959 2 door wagon rear seat hinges
  131. Steering PS Hose Routing 62 GT
  132. Steering Steering Column lengths, Boxes, & Wheels
  133. Body: Weatherstripping for Lark HT
  134. Engine: what is correct sequence of pulleys for supercharger (Golden Hawk)
  135. Engine: Oil Pressure 'plunger valve' direction; I assume the way it WAS is WRONG?
  136. Transmission: Did Studebaker change internal cooling design for 57 Golden Hawk A2-7A transmission?
  137. Steering Power steering for a '53-'55 C/K
  138. Engine: 63 Daytona wants to die when put in gear
  139. Ignition: Timing way off
  140. Interior: Toggle switches
  141. Electrical: 38 State Commander Tail Light Lens Removal
  142. Electrical: Prestolite Alternator Wanted
  143. Electrical: ammeter to voltmeter swap
  144. Wheels Tire Tread Width
  145. Other: "3 on the tree"
  146. Fuel System: carburetor flow rate
  147. Fuel System: Servicing Supercharger
  148. Brakes: Power brake problem
  149. Drive Shaft Rear end shimmy
  150. Engine: C Body Engine Removal Clearance
  151. Fuel System: Gas gage ohm rating and tank
  152. Steering Wild Steering Wheel Oscilation!
  153. Engine: Head bolt torque
  154. Engine: WCFB Air Flow Limit
  155. Electrical: horn wire
  156. Fuel System: Fuel Line
  157. Other: How bad would it look...tires
  158. Transmission: T10 4 spd. Bell housing??
  159. Engine: Help - Engine Smokes After Long-Term Storage
  160. Engine: 1940 Flat Head Freeze Plug Came Out
  161. Engine: What order do pulleys go on for 57 Golden Hawk w/ Power Steering?
  162. Engine: Anybody ever use these freeze plugs???
  163. Fuel System: Stromberg WW fuel evaporation
  164. Electrical: Ammeter reading
  165. Engine: Intake/Exaust Gasket goo?
  166. Transmission: 49 champ 3speed,r-10 BW
  167. Cool/Heat: Which heater hose is the pressure ?
  168. Electrical: dash lights
  169. Interior: 1954 Land Cruiser - Looking for Trunk Carpet
  170. Engine: Top Speed
  171. Body: Avanti Window Regulator Manual VS Power
  172. Clutch/Torque Converter: 1949 Clutch Adjustment
  173. Exhaust 56 J exhaust extention
  174. Body: Door/hinge shims, trying to get my hardtop's door to shut right:)
  175. Rear Axle: Help with rear axle and emergancy brake
  176. Body: GT Hawk Upper Window Stop Filler
  177. Steering Power Steering Mounting
  178. Wheels Need One 1957 Golden Hawk Hubcaps Wheel Covers AC 2799
  179. Engine: 289 Flywheel?
  180. Transmission: 3 speed manual shift rods
  181. Electrical: prestolite 4108
  182. Engine: Key differences between Studebaker 289 and more common engines when rebuilding
  183. Engine: Front Crank Seal, Revisited
  184. Interior: Remove Rear Seat 64 Cruiser
  185. Engine: Greetings to All - New to the Board - With Questions
  186. Engine: 1961 V8 paint codes
  187. Brakes: adjusting proportioning valve
  188. Engine: 289 block
  189. Engine: Champion 6 front crank seal
  190. Electrical: Voltage decreasing at the coil.
  191. Steering lower outer pin
  192. Body: Seat Belt Installation Template Needed for C/K
  193. Electrical: Horn wire
  194. Body: Mirrors / Trunk/ Steering Wheel on 1957 GH
  195. Engine: Valve Spring "Clips"
  196. Steering steering box lube
  197. Engine: 1957 Golden Hawk Engine compartment
  198. Wheels 1957 Golden Hawk Tiires
  199. Interior: 1957 GH Trunk recommendations with repaint
  200. Electrical: Replace Turn Signal Switch
  201. Engine: Spark Plugs for '50 Champion Engine
  202. Electrical: 49 champ dash removal
  203. Engine: valve guide seals
  204. Steering stubborn pittman arm
  205. Body: Avanti Manual Window Regulators
  206. Transmission: 1954 Champion with 1964 259 V-8 upgrade to GM turbo 400?
  207. Brakes: 1954 Champion with V-8 disk brake conversion upgrade
  208. Engine: 289 Valve Stem Seals
  209. Body: Molding Clips
  210. Cool/Heat: Radiator Cap ID (Was: "Don't Know")
  211. Ignition: Vacuum Advance bleed down
  212. Steering TPI 350 install in 65 Wagonaire
  213. Transmission: Complete Hurst 3-speed Syncro-Loc shifter and brackets for T86 w/OD
  214. Engine: 6 cyl intake
  215. Frame/Springs Questions re: frame
  216. Engine: 289 Rod/Main Journals
  217. Fuel System: Unsticking throttle shafts
  218. Other: Part number and or id - Solved! Cowl Drain
  219. Body: Do I have to remove the gas pedal bolts from the floor ( install SI vendors carpet) 55 president
  220. Fuel System: Here's what to do with your spare time.
  221. Engine: 55 Commander Project
  222. Cool/Heat: Dash knobs
  223. Rear Axle: pinion oil seal Dana 44
  224. Body: 59 Scotsman Pickup - Right front Fender
  225. Frame/Springs Bat wing
  226. Engine: Weight of 289 & T86
  227. Body: Front fender patch
  228. Drive Shaft '63 Hawk Drive Shaft Orientation
  229. Body: vinyl top
  230. Steering Power steering harder to steer to the right
  231. Electrical: 56 gh turn signal switch
  232. Engine: lack of Zddp
  233. Shocks coil overs
  234. Brakes: Adding Dual Master Cylinder
  235. Engine: Engine Compartment 1957 GH
  236. Transmission: T-96 information needed
  237. Brakes: Brake booster reserve tank
  238. Electrical: Tachometer
  239. Engine: Off With Its Head!
  240. Engine: Seeking 57' GH Stock Valve Cover in Black as Stock and air cleaner cover in Aluminum
  241. Engine: Occasional Knock
  242. Engine: 57' GH water temperature
  243. Steering Power Steering Pump Interchange
  244. Engine: Improved Super Lark!
  245. Speedo/Tach/Gauges Cable length
  246. Transmission: Used Valve Block Core
  247. Engine: Engine cuts off
  248. Wheels Nos rims ???
  249. Steering Lube question
  250. Interior: 1954 Champion Gauge Cluster Removal
