View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. conversion to an alternator ????
  2. Lark Frame question
  3. Axel nut tighting procedure
  4. sticky tach
  5. Crank hub installer
  6. 1953 starlite
  7. Fuel Pump Question
  8. changing out the rear quarter on a wagon
  9. Freeze Plugs
  10. 56 body mounts
  11. PVC valve arrow
  12. 53 commander fuel guage
  13. 53 commander tranny swap
  14. 50 champion dash wiring help needed
  15. Overdrive wiring
  16. Avanti broken exhaust bolt patched, now polishing
  17. Heater Core for 1957 Silverhawk
  18. Need Paint Mix Code for 57 GH TIARA GOLD Poly.
  19. official paint colors
  20. Cleaning 50 years of grunge
  21. Top Dead center
  22. Speedster hood question
  23. Avanti Rear Brakes
  24. Drive shaft won't slide in
  25. A warning for Avanti owners about their hood latch
  26. 47 to 52 Convertible Rear Window
  27. Front end rebuild question
  28. Automatic Trans Question
  29. BRAKE LIGHTS
  30. power steering hoses
  31. Mystery Noise on Left Turns
  32. T-Cab mounting questions
  33. Lark won't light
  34. OD kickdown troubleshooting
  35. Hydrovac repair
  36. Still Seeking Clock
  37. Steering question
  38. 60 Hawk Question
  39. Identification
  40. Timing gear/chain?
  41. what year is this truck?
  42. Speaking of clocks...
  43. engine boring
  44. Avanti R2 alternator conversion
  45. 56-57 first gear start.
  46. Low Oil Pressure Revisited - Rebuilt enigne
  47. 1955 President 259 Oil Pump
  48. How do I paint an engine with surface rust?
  49. headlight flicker and brightens on own
  50. Moving disk hubcaps
  51. Adjusting the emergency brake cable
  52. Speedometer Pinion
  53. condensation in gauges
  54. Thermostat temperature
  55. wheel alignment
  56. Hydraulic lifter conversion?
  57. Question
  58. 1962 GT Hawk A/C question
  59. want to trade overdrive solenoids?
  60. 82-02 Camaro front seats in an Avanti - How to
  61. smoking generator
  62. Wheel bearing grease...
  63. Reach Rod end needed for Champ
  64. Accelerator Sticking or Haunting?
  65. Securing the ignition switch
  66. Vin # location on Avanti
  67. anyone know anything about Weasels
  68. Clock Installation
  69. Wheel backspacing
  70. Intake Manifold
  71. Engine numbers
  72. Wheel cylinders - bleed valve
  73. Balast or resistor on coil
  74. Dana Inner Bearing SEAL
  75. Speedometer
  76. Prewar Steering column question
  77. Need some color information
  78. Thanks
  79. Mr Biggs, transmission mechanic?
  80. Headliner Installation
  81. Edelbrock install report.
  82. pedal car 1957 Studebaker pedal car
  83. 4 pole GM- style starter mod
  84. Clutch Help?
  85. Auto trans rebuild
  86. 6 VOLT BLUES... 12 V CONV?
  87. What cars does this fit?
  88. Hawk door handle
  89. Title question
  90. Hawk Door Trim
  91. Coil 'polatity'
  92. Gas gage 50 Champion Weird behavior
  93. Top shift conversion for a Lark 8
  94. engine compartment paint scheme
  95. Avanti R1 fuel pump leaking out the top-revisited
  96. 60 Lark gas line
  97. buying a 259
  98. Installing an Edelbrock
  99. Can anyone decipher this trim code?
  100. do these brake shoes fit a Studebaker?
  101. Windlace Installation - Fabric Extension
  102. Need advice-stuck exhaust valve-63GT-289
  103. 59 Hawk Radio Model
  104. P195 75 R15 Tires
  105. Courtesy Light
  106. Index of Serial Numbers
  107. Seat Adjusters
  108. Parts from Omaha to Laramie Deilvery???
  109. Frank Morgan aluminum head and intake
  110. Installing Anchor Points on a Lark VI
  111. Electric fuel pump
  112. Ammeter dance
  113. headlights going on and off
  114. avanti paint
  115. What does power steering pump 1550422 fit?
  116. master cylinder?
  117. value of 57 hawk eng etc.
  118. Got fuel pump rebuild kit,torn rubber piece? HELP!
  119. Got new 63 Avanti round headlight gaskets .. WTH?!
  120. Valve tic
  121. Dana 44 Axles-Help
  122. Worn out 289 with sticking intake valve??
  123. Transmission
  124. Problem, big time
  125. 64 Hawk Welding Trunk Pans
  126. Overdrive partly engaging
  127. What year does this part fit?
  128. crankcase fumes
  129. Look at lifter !!
  130. Project A: SILVER Dana 44 axle/differential
  131. generator problem
  132. speedometer cable malfunction
  133. Hill Holder
  134. Starter Tags
  135. 29 Colors? interested in Studebaker Avanti Colors
  136. Axle Bearing Seals
  137. Gas gauge
  138. dual exhaust how to ????
  139. 6-to-12 Volt Conversions
  140. Torque on crank bolt
  141. Header Flanges
  142. On-line searching for Stude parts
  143. Braided battery cables
  144. Trunk rubber
  145. More T-Cab steering woes
  146. local chapters
  147. THANK YOU!!
  148. R1 fuel pump rebuild proceedure - w/pics!
  149. Starter ID
  150. trunk handle re-assembly, 1952 (see pic)
  151. 1959 lark VI *ENGINE QUESTIONS*
  152. Fan , front side?
  153. Studebaker Bolt pattern
  154. Avanti title
  155. Polarizing my Generator
  156. Project A: 43 “paintable” parts on Avanti
  157. Correct door handles 41 M Truck
  158. rotella engine oil
  159. Kroil (for those of you that use it)
  160. Distributor vacuum port
  161. 1950 Studebaker Land Cruiser Fuel Pump
  162. Car fixed
  163. Omaha from the West
  164. part number?
  165. 1952 2R5 Pickup engine size
  166. Speedo woking intermittently
  167. Project A: Need Rear Drum Brake Part Info
  168. Adding power steering?
  169. Stromberg model WW
  170. trouble with the 37 again
  171. Stuck Engine 63 Lark
  172. Hawk Fin Strip Molding
  173. 64 t cab -- splash shields
  174. Body Lift Points & Body Cradle for Avanti
  175. chassis detailing on 1963 R2 Hawk
  176. pinch bolts
  177. Transmission help.....
  178. "New" 289
  179. front springs sagging?
  180. Engine rebuilding info for a 1950 Champion 6?
  181. Help, really quick engine swap needed
  182. Project A: Leaf Springs Removal and Arching
  183. Project A: Sleeving Rear Drum Cylinder
  184. Spun a bearing?
  185. GT Hawk ignition switch
  186. road draft to pcv
  187. Fuel pump mounting bolt fell into Bermuda Triangle
  188. thanks for Avanti Parts Manual Scan/Fax!
  189. 64 daytona wideshield
  190. 1950 Champion Land Cuiser NEWS
  191. FYI: General Warning on Parts Manuals
  192. 1948 Landcruiser
  193. oil drain hole
  194. Vacuum Hose Diagram 1950 Land Cruiser
  195. Oil Pressure Plunger Stuck
  196. VIN for 57 Hawk
  197. Studebaker Performance
  198. T96 OD Trans
  199. R1 Avanti air filter number and oil change time!
  200. machine shop
  201. T10 Manny Tranny Questions
  202. 1961 Hawk headlight bulbs
  203. 1950 Heater Contol Valve
  204. halogen bulbs 1157 ?
  205. Champ (not Champion) gas guage
  206. Project A: Avanti cruise control
  207. 50 Champion no start when hot......
  208. Have R3 Air Box(Adaptor), will exchange for R2
  209. Help again. 50 champion front wheel noise
  210. gaskets trouble HELP
  211. Project A: R&R 289 SC Oil Pan
  212. Project A: R&R 289 Rear Oil Seal
  213. Project A: Add-a-leaf
  214. transmission shifting
  215. Hawk taillight assembly question
  216. stude vs. fords 289
  217. Torque converter interchange?? 66 to 62??
  218. 59 lark VI GAS LEAK help!
  219. vibration
  220. Pistons and rods?
  221. Wiring Harness
  222. headlight ring part # ????? please...
  223. trans shifting
  224. 50 Stude dash light question
  225. LandCruiser shoes/cylinders ?????
  226. Lark steering box leak
  227. Studebaker Distributors
  228. Hawk fender lights-signal monitor ??
  229. TT Rear Axle
  230. Headlights : Euro / Halo
  231. starter trouble
  232. Brake Drum Removal ?
  233. Instrument light switch
  234. My first Stude! Was running but now won't start!
  235. Year the automatic shift pattern changed
  236. DL Steeltech disc brakes
  237. Vacuum Gage
  238. Project A: Rear Suspension Delrin
  239. headlining removal
  240. 53 commander coupe
  241. 51 Champ Trans Bolts
  242. steering wheel adapter
  243. coolant leak
  244. How do you fasten cat whiskers?
  245. Uneven brake lining wear
  246. Project A: Changing Speedometer Pinion
  247. 51 Studebaker Champion Motor Mounts
  248. Chrome wheels
  249. Paint on Vinyl Interior
  250. Powershift shifter adaptation
